ROCCAT KOVA ULTRA-LIGHT GAMING MOUSE - ONLY £34.99 INC. VAT
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Roccat Kova Ultra-Light Gaming Mouse @ £34.99 inc VAT
It doesn’t matter whether you’re left or right handed, you use a PC or a Mac, or you’re a fan of red, blue or green – the ROCCAT™ Kova satisfies any wish; and it does all that without you needing to install additional drivers. With this component of the ROCCAT™ SDMS, another foundation stone has been laid for feature-packed, efficient gaming.
As part of the ROCCAT SDMS, the Kova has been fine-tuned for pure performance. The mouse can be configured just by pressing simple button combinations - and all without the need for drivers. For instance, the dpi resolution can be increased from 400 to 800, 1600 or even 3200dpi without needing to go through the tedious process of configuring the software - and it's just as easy to switch between right and left handed mode. The 5 (+2) mouse buttons come preset with the most important functions for all the latest games and applications.
The ROCCAT Kova features a customizable lighting system which can be adjusted to suit at the press of a button. You decide which color the mouse should light up in. The discrete LEDs on the sides of the mouse will cast an atmospheric aura on your desktop, particularly when you set them to pulse slowly.
The LEDs also indicate the dpi setting you've selected with the help of the dpi-change feedback system. The default resolution is 800dpi. By simultaneously pressing mouse buttons 5 and 7, the mouse will flash green twice, indicating that the dpi setting has now been changed to 1600dpi. Change the resolution again and the mouse will flash blue twice and the resolution will increase to 3200dpi.
- 3200DPI pro-optic gaming sensor
- 7 Mouse Buttons
- Driverless Configuration
- Full Compatibility
- Customizable Lighting
Only £34.99 inc VAT.
ORDER NOW
Looking at my right hand using my mouse right now and it would seem that my middle finger rests where those left handed buttons are. It would be quite annoying if your resting fingers kept catching the buttons.
Also,
"The default resolution is 800dpi. By simultaneously pressing mouse buttons 5 and 7, the mouse will flash green twice."
That sounds pretty awkward to me!
I think this picture shows it off better.
MY ROCCAT KOVA
I had to send my ROCCAT KOVA back to another retailer twice because it would not work with my pc, and others have had similar problems especially with Windows 7. I finally got a refund today and now I'll be waiting for my Razer Lachesis to arrive!
