Roccat Talk Help
2 Jun 2013
Glasgow
Hi,
I have a Roccat Kova+ and I recently bought a Roccat Ryos MK to go with it.
However I have installed both drivers and then installed roccat talk but I can't get the EasyShift on the mouse to work for the keyboard and vice versa.
When I right click Roccat Talk in my startbar it only shows configure keyboard and not the mouse.
All help is appreciated.
Thanks
Can you run the mouse config program ?
To use easyshift for both you need to tell the profile to do both. it wont do it by default. As in on the mouse profile, set a button to "Easyshift both"
Other note, I believe in windows you need the extra driver to interact with each other.
http://www.roccat.org/Support/Support-ROCCAT-Technology/ROCCAT-Talk-FX/
However after looking on the roccat site, dont think the kova+ supports it
If it has TalkFx on the box it will do it, think the kova was out before they implemented it.
Have a look see if there's a FW upgrade. you never know....
I know the konextd does as that's what I have + a isku fx.
Got my lad the Ryos MK + their new mouse, odd thing with loads of buttons :eek:
What's the KB like if I may ask? Not that I have any complaints with isku, just curious:D
I was debating between the Isku FX and Ryos MK. Glad I went for this. Apart from not having the lighting effects the keyboard is solid. Its my first mechanical keyboard but the typing just feels so smooth.
Hardware is very solid also, build quality excellent.
Looks like I might need to upgrade the mouse soon... only had it months aswell.
