Rock Band question
18 Jan 2004
Sunny Scotland
Hi
I have Guitar Hero World tour and the guitar for PS3 I want to get rock band 2 and also fancy playing workd tour again aswell with some drums.
Will my guitar hero World tour guitar work with rock band2?
Which drums should I buy and will they work with RB2 and GH:WT
I dont want to spend a fortune and I noticed I can get rock band 1 drums really cheap or I can get the RB beatles value kit with drums aswell. Any ideas whats best.
Cheers.
you'll be able to use the gh:wt guitar with rock band with no problems
the rock band drums only has 4 drum pads (no orange iirc), so you might run into problems with that. not entirely sure so someone correct me if i'm wrong :)
Rock Band drums work fine on GHWT/SH/Metallica, it takes away the orange and adds another note elsewhere. Notes also seem to come down faster on the chart.
cheers for that cna deffo see about about getting some rb drums, do you know if the GH drums work on RB
Sweet cheers for that bud, can get a Rock Band: Band in a Box Peripheral for PS3 and PS2 which is the drums guitar and mic for 50 quid. thinking of going for it.
the only problems i have run into
mettalica, rb drums wont be able to do the training
rock band 1 needs the updates to get gh guitars to work
ps3 btw
