Rocketdock icons?
23 Jul 2009
Bath
Having decided to get rid of a set in favour of a new one, I've discovered that the stack docklets' icons don't stick after a reboot. Some are the old icon set, and some revert to the stock setting of just a transparent square. Can anyone advise me as to how I might fix this? Thanks
Dev
EDIT: Just discovered one docklet disappeared, and another lost all the settings I had applied to it (ie no folder attached). wtf?
Stacks gone after restart? Here's the solution folks:
Log in as admin to have the administrative rights.
1. Navigate to the RocketDock folder under program files...C/Program Files/RocketDock.
2. Right click on the RocketDock folder, and select properties, click the security tab at the top.
3. You should see a list of groups and user names of your pc, click edit...
4. Click on your user name..should be called "Users(your name)"
5. Check the box underneath to give yourself "Full Control", click Ok, Ok..
6. Done, your user account now has full permission to this folder...try it close the application or restart and you settings should be saved
They never used to though, even with the old set of icons I installed. It's only since trying to change the icons a second time that it's started doing this. I'll give that a shot though and will report back.
