Just noticed there is a new bios out but i am wondering since i use a lian-li vertical bracket with a pcie 3.0 riser it did say in the box make sure you set it manually to gen 3 (if using pcie 4 gpu) in the bios, since when i install a new bios this will wipe my presets and possibley cause issues with the gpu?
