- 25 Mar 2025
- Scotland
Hello everyone first post, I'm having an issue with this motherboard that i hoped maybe someone might have some other idea's about the issue.
I recently changed my main PC to a 9950X3D, which left me with a 7950X3D spare. I had plans to build another PC for other uses so i decided to buy parts to put one together.
I decided to do what i've never done before and bought a 2nd hand motherboard from Ebay, which the seller deemed "Used for a few weeks this item is in mint condition" which it was, it looks imacculate and i couldnt see any issues with it.
Initial power on it worked straight away and i had no issues with it so i deemed it working.
The main issue im having now however is whenever the PC is switched on from a completely cold boot, ie no power to the psu/not in standby, I get the 00 code and the DRAM light is orange, if i press the cmos clear button on the back of the motherboard and then power on, it boots normally and i get to bios, save and reboot and from there i get into windows fine.
If the PC is left with power to the PSU, ie Motherboard LEDs are lit, It does not give this issue when switching on, it is only when there is no power left to the board for a period of time.
At this point, bios settings are all default
Things i've tried are:
Brand New CMOS battery (Freshly bought)
Different RAM set - I have 2 identical RAM kits (G.Skill Flare X5 6000mhz CL32) Both kits work flawlessly in main PC without issue and don't show errors in memtest so i've deemed the RAM itself as OK
Different BIOS versions (2904 and 2806)
Re-seated the CPU multiple times
It functions perfectly and doesnt appear to have any issues under use, it passes OCCT 12hr stability tests, memtests etc, in other words it works flawlessly other than this cold boot issue.
My thought is its bios related given that cmos clear allows it to boot normally, unless there is something i'm missing im not sure what else to try.
Could this potentially be PSU related, or is the motherboard just deemed faulty at this point?
Any help greatly appreciated, Thanks.
