rog maximus x formula problem
24 Mar 2004
kintyre
working perfectly until boot up this morning,then hung at code 99 load vga bios,reset cmos loads of times and tried a different gpu.only republic of gamers splash displayed and can not get into the bios,tonight i tried asus usb flash back with no joy. is there any thing left for me to try before RMA?
cheers fletch.
cheers fletch.
Its not good news, if it was working fine before, and you've not messed about with anything, then RMA the board.
http://www.asusqcodes.com/index.php?inputCode=99
Code 99 was found! See description below.
Super IO Initialization
This may be due to various reasons, a failure in the BIOS or defective or faulty motherboard. You can try to disconnect the Graphic Card and use integrated on the motherboard. If this does not work, another option would be to make a BIOS FLASHBACK to downgrade the BIOS, simply record the specific files to a USB pen drive, connect it to the PC and then turn on the PC by pressing FLASHBACK key on the motherboard for more detailed instructions you can check this video in Youtube:
