My PC I built won't boot. When I connect my monitor I see nothing, only black screen.
Yesterday I thought I fixed the issue. The PC actually booted and worked fine after I cleared CMOS header by unplugging the onboard cell battery and touching the two pins as written in manual with a screwdriver for 10 seconds. Before I turned the PC on I plugged the onboarding cell battery back. I unscrewed the back cover on the motherboard to get to the cable (see picture).
However the next day when I turned the PC on, I can only see black screen on my monitor. I did check the monitor and cables by using my MacBook and it worked flawlessly.
I noticed there is an orange / yellow light on the motherboard when I turn the PC on. According to the manual it is DRAM Q-LED. Also the motherboard doesn't give power to any of its USB ports on the back. I know this because my keyboard has backlit keys and they turn on when the PC is on.
Today I tried:
What would you recommend I try? Thank you in advance for any help!
Today I tried:
- Removing both RAM sticks, cleaning the pins with a brush.
- Try only 1 RAM stick. I tried both and still I only see black screen.
- I reseted the CMOS header again. I tried both with and without unplugging the cell battery. The issue remains.
