Hi all, I recently purchased this monitor and ordered a sim racing mount/seat etc.
The monitor is brilliant, the colours and refresh is perfect but the light bleed is poor when in a dark room
According to the OC website it states that it's VESA mountable, but due to the indentation on the back it's impossible to mount. I've even tried it on an expensive monitor arm to get me by, but the dimensions of the bracket make it impossible to fit flush/flat (the bracket doesn't even fit the small opening).
I've contacted support and had the following response -
https://manuals.coolblue.nl/72/asus-rog-strix-curved-xg43vq.pdf
section 2.3 shows this monitor is VESA mountable and all the details should be shown under this link.
Use only the UL Listed Wall Mount Bracket with minimum
weight/load 28.8 kg (Screw size: M4 x 10 mm).
The PDF also states contents include a VESA kit, but I've seen nothing like that in the box.
Has anybody else successfully mounted this monitor or know of s solution?
It's not exactly cheap and expected it would have come with some sort adapter like other large curved screens.
Cheers
Cheers
