Rog strix z270f gaming no power after case and aio change
31 Aug 2019
Hi folks, I bought a corsair h150 pro rgb and lianli dynamic today from OCHQ in Newcastle. I moved my current mobo whixh was working fine this morning to the new case and installed the aio,
However, now I cannot even turn my pc on. The Rgb for the strix is on, so is the orange light that is supposed to show its in standby. When I press the power button though, the rgb for the h150 flashes for a brief second but nothing happens at all. I'm sure everything is seated correctly, I've even tried powering up with nothing but the h150 and ram in there but still no dice. Have i knackered something?
Try loosening the mounting screws of the cooler.
Then try building it outside of the case with the minimum plugged in, and no case cables (Start/Reset etc). Jump it with a screwdriver flat tip on the two start pins.
Cheers Danny,
I had a check over everything this morning, turns out it I was an idiot last night and tried to power the graphics card with the Sata ports on my power supply.
As soon as my wife took one look and went, "Why are you doing this?" I knew I messed up.
Oops. I blame it on being really utterly late and I was shattered.
Thanks anyway.
