Hi all,
First of all I hope I've posted this in the right thread
I wonder if anyone can shed some light on this my pc had started to not turn off, when I would try to turn off the PC the monitor would go off but the PC itself would stay on, so after googling it I decided to do a Bios update which worked out ok ish, after the update my windows 10 OS would just hang so I ended up installing windows 11 which I had intended doing anyway so not to worry, everything is working well and the system seems stable but the one thing is that my Lan isn't working, even when I look at the back of the computer the little lights on the Lan port are not working, If I go into the Device manager everything seems normal no yellow ticks that tell you something isn't install correctly, it's as if the computer doesn't know there even is a Lan port, I have tried to d/load the drivers for the Lan of the Asus site but when I try to install them it comes up with an error, usually it's this PC doesn't support this ?
I can still get online via wifi but it still doesn't explain why the PC doesn't even see the Lan port.
I have tried all the help tips on Youtube but none of them help, I might either try reinstalling windows 11 again.
My system spec are :-
Mobo:- Asus ROG Strix Z590-F series
Cpu :- i9-10900k
Ram :- 32GB
OS :- Windows 11
Any help would be great
Cpu :- i9-10900k
Ram :- 32GB
OS :- Windows 11
