Rogue Trooper - unplayable FPS on Hoppa Chase level
Man of Honour
25 Oct 2002
Hampshire
Currently playing through Rogue Trooper (Steam edition on Win7x64). Everything has been fine up to now, typically around 300-900fps on my i5 @ 4ghz, GTX470 setup.
However, the Hoppa Chase level where you are manning some kind of aircraft turret is literally unplayable from the start - as in it runs at about 1fps at best making it impossible to aim or well do, anything.
Looking on google it seems to mainly affect Vista/W7 64bit systems, but I haven't been able to find a fix. Setting compatibility mode to Win98/ME was suggested, but the Steam version won't run if you do that.
So, does anyone know of a fix for this?
Cheers.
***EDIT***
In case anyone else searches and finds this thread in future, I was able to fix it by setting both Steam client and the game to WinXP SP3 compatability.
Just completed this, my view:
+Reasonable array of weaponry
+GI implants add a bit of character
+Special abilities like setting up turret, hologram projector etc are nice, although to be honest most of the time I just went in rambo style
+Performance is excellent with the exception of the above issue (to be expected due to game age)
+'On rails' sections are nice to break things up a bit, I'm a bit of a sucker for these sort of things
+Salvage system works quite well although you never run out so can just take all upgrades rather than being forced to choose between them
-Graphics are pretty poor for a 2006 game, especially close up textures on vehicles and character models. Even 2004 titles like FC, D3 and HL2 look much better IMO.
-Very contrived approach to enemy vehicles - there always seems to be a bazooka, flak cannon etc handy
-Controls feel a bit fiddly and 'console-portish', e.g. the reuse of the use key for multiple things
-Quite a short game, over in about 6hrs on normal difficulty.
