ROME TW WON'T UNINSTALL - help!!!
28 Oct 2011
Ok, I 'uninstalled' using windows in the conventional manner, that went to install, inserted the disc and the options were 'play' and 'uninstall' no mention of 'install'.
Prior to this on the add/remove panel, at the bottom there was an entry for RTW but no file size. So i used revo uninstaller pro, that removed the entry, but did not improve the situation.
I've deleted files and folders and 'cleaned up registry' etc - still get it RTW to install.
check to see if there are any associated keys here:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
CurrentVersion all one word
Creative Assembly
might exist or
LOCAL_CURRENT_USER\SOFTWARE\
Creative Assembly
I dont have it installed but thats my best guess
Other than that what you can do is use process monitor
switch to reg only mode and insert the disc and see which keys it is accessing
just make sure only the reg icon button is de-pressed
edit: to be clear mouse over icon 5th from right
Show Registry Activity is tool tip
