Hi Guys
We had a company come in last year to do some landscaping in our back garden and said that wet look on the newly laid black lime stone would look great, however it appears that Ronseal isn't as good we we/they thought and it has to be applied over the hottest and driest days possible, its rained that day after they put it on the 50sqm and it appears the wet has come back up and got trapped behind the slabs sealant. I contacted the company we used and they have said it must be the product and to go back to the manufacturer (cowboys.... won't be using them again!) I've contacted Ronseal and good enough out of them they sent me a pallet of cleaner and satin finish but the cleaner did nothing even though I scrubbed and used my Karcher jet wash to try and clean it off. I'm happy to use something stronger but not sure what options we have. I spoke to a company and they charge £30 per square metres which would cost me close to £1,500.00.
I'd be happy for it to go back to the normal lime stone color and texture if I can find the right stripping product and may but a stronger jet wash?
Any help/advice would be great!
Pictures below
Pictures below
![img](https://i.imgur.com/krRblMI.jpg[/img)
