USB headers on mobo are for those ports of controller which didn't fit to back I/O panel so I don't see how using them has anything to do with USB devices you're connecting motherboard.
I dont get what you mean? You dont need to have them connected. Just remember that they arent connected and will not work. You can buy / acquire pci plates that fit into a blank slot and connect to your existing mobo header. That will break them out to the back instead of the top of the case.
