Roof Racks
18 Apr 2007
Probably in a river somewhere
Hello all.
I'm looking to get a roof rack for my 08 Fiesta so I can transport my kayak around instead of relying on others.
Thule seem to be the big name brand, are they worth paying the extra for? Or do any of you have other reccomendations?
Thanks for the help!
I've got some really skinny Thule luggage straps that I used to use for strapping stuff to my bike. I now use them for hauling stuff about in the garage and lifting engines out the car. They were expensive, but I wouldn't use the £2.99 Aldi specials for that job.
Thule are expensive though, I agree.
We picked up the cheaper of the Thule roof bars for our Focus. You get what you pay for. Halfords ones, for example, are a bit harder to fit, don't fit as well (they rattle more when you're driving) and don't last so well.
/anecdotal evidence based on my experience and that of a few people I've spoken to about roof bars
Atera are worth a look. I've also been hearing good things about Whispbar recently too.
I went cheap with my ones and bought Cruz bars (choosing to spend more money on my bike carriers) but as has been said you do get what you pay for. The fixing bolts on my Cruz bars are shot (not a big issue) and 3 of the four end caps have broken (one whilst driving never to be seen again!) but they have been used 100 - 150 times at a guess and still do the job.
As someone who worked for halfords for nearly 4 years and this fitted countless sets of roof bars, its got to be Thule - easier to assemble, better made and a better fit.
For example the Thule fitting kit and foot pack you will buy will have car/model specific parts with rubber feet tailored to that specific vehicle, ensuring a proper fit with the bars sitting as straight as possible regardless of any curve/camber to the roof or rails, and with reduced likelihood of marking the roof rails or paintwork where they touch the vehicle.
Thule bars have thicker and better shaped rubber pads where they touch the car compared to cheaper sets which are often more generic in design (a more generic design such as the halfords own brand range will fit more vehicles easily without the need for as complex and vehicle specific fitting kit, and thus is cheaper to buy, but will be fiddlier to fit and more likely to damage door seals, roof rails or paintwork with repeated use). The halfords bars come with thinner and harder pads on the attachment points - with Thule you are much less likely to mark the paintwork where the bars attach to the car
Thule are expensive but if you take them on and off a lot the ease of fitment will repay you! The halfords own brand stuff is horrible in comparison, I used to dread being asked to fit the 'value' halfords sets. I wouldn't bother with the Thule aero bars, they look nicer but that's about the only advantage over the box section normal bars for most applications.
Do you have roof rails??
If so then Mont Blanc is the way to go over Thule, 60% of the cost, same quality - i got some a few weeks back for my kayak and they are superb, areo bars and feet all in one easy to fit kit for £80 delivered :D
Whatever you get dont go to halfords, they are incredibly expensive compared to almost everyone else.
