Roof tile identity
21 Jan 2008
Cotswolds
Hi all,
Bought a house just before Christmas and found I have a leak in the workshop (not declared) and have found two tiles are cracked. I think they are Marley Ludlow tiles:
Any idea where I can get a handful of these, two to replace those broken and a few spares to hand...
Cheers,
James
I Googled it, found this, don't know reputation of company though:
I would get that moss cleared off the roof whilst you're at it as well (or is it just the workshop? either way won't do it a lot of good).
So did I..problem is this bit "Must be ordered in Pallet Quantities (216 per pallet)"
I only need a few!
Yes, it's on the list of plans to get sorted but it's only the workshop/garage so it's low priority - sorting the cracked tiles is higher as I don't want my stuff getting wet!
Reclamation yards quite often have old roof tiles and will usually let you buy a few at a time.
You can also keep an eye of local marketplace as you quite often see leftovers advertised.
Another option is to contact local roofers. If they have a job on using the same tiles they will usually have leftovers
