- 14 Jan 2010
- Dover, Kent
I am running a Q9550 with a Freezer 7 Pro R2 cooler. Currently 3 internal fans, one 80mm on the side blowing to the cpu heatsink, one 120mm on the top of the case blowing outwards, and a 120mm fan on the front blowing inwards.
I've set the frequency to 355, and set the voltage to 1.250v.
Doing a quick burn test shows temps which normally stay in that region even after long tests. Thing is, when its doing the test my voltage seems to go down, but when speedstep is active (see bottom left of image) it goes back to 1.250 volts.
Am I missing something stupid out here making the voltages do that? And also what would people suggest for me to go a bit higher (or can't I with these temperatures?)
Hope this makes sense lol, thanks.
