rosetta started
im also looking at the folding@home one because a lot of people are doing it on here, i can install 1 and everything is fine but can seem to get another one working, ive created a new folder and made a copy of it but it keeps saying ive already got one running, if anyone can help me id appreciate it, ive read the guide but find it confusing
you need to run the second one with the -configonly command and change the Machine ID from 1 to 2
if you try and run two clients with the same machine number it'll stop the second one to save your machine processing the same work twice
edit: all the information for getting into the configuration is in this post of the sticky
it's the last question you're asked in the advanced settings
Machine ID ( 1-8 ) - just enter 2 there instead of 1 and you should be fine
