ROUND 1 - EARLY BIRD WEEKEND DEALS - POWER SUPPLIES
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys
Some great PSU deals here :)
OCZ ModXStream Pro 500w Silent SLI Certified Modular Power Supply @ £46.99 inc VAT
nonl2brThe ModXStream Pro Series is the superlative solution for driving today's gaming systems, and can power both NVIDIA® SLI™ and ATI CrossFire™ modes. Professional-grade yet designed with gamers and modders in mind, this PSU is stable, robust, and sports a sleek look and compact form factor. Kept ultra-cool with a load-controlled 140mm fan, the ModXStream Pro was engineered to be the quietest PSU available and eliminate distracting noises from your PC. Highly efficient, featuring up to 86% efficiency at typical load and up to 82% at full load, this leading-edge power supply remains rock solid and powerful while retaining superior efficiency under load. <br>
The OCZ ModXStream provides Universal Input and Active PFC (Power Factor Correction) to effectively regulate input voltage across worldwide power grids and maintain an economical, stable supply of power. Available in configurations ranging from 400W to 700W and backed with OCZ’s 3-year “power swap” warranty, the OCZ ModXStream Pro gives you the ultimate power and peace of mind to ensure the stability, low noise, optimized air flow, and efficiency of your gaming system. <br><br>
- 150 x 160 x 86mm (W x L x H) <br>
- ATX12V v2.2 and EPS12V <br>
- up to 86% Efficiency <br>
- Overvoltage/OverPower/Short-Circuit protection <br>
- (.99)Active PFC <br>
- MTBF: 100,000 hours @ 25C <br>
- 1 x 20/24-pin ATX <br>
- 1 x 8-pin CPU <br>
- 1 x 4-pin CPU <br>
- 1 x 6-pin PCI-E <br>
- 1 x 6+2-pin PCI-E <br>
- 4 x Peripheral <br>
- 2 x Floppy <br>
- 6 x SATA <br>
<br>
Was £52.99 Inc. VAT
Only £46.99 inc VAT.
ORDER NOW
OCZ ModXStream Pro 600w Silent SLI Certified Modular Power Supply @ £52.99 inc VAT
<br>
<br><br>
- 2 x Floppy <br>
- 6 x SATA <br>
Was £59.99 Inc. VAT
Only £52.99 inc VAT.
ORDER NOW
OCZ ModXStream Pro 700w Silent SLI Certified Modular Power Supply @ £67.99 inc VAT
<br>
<br><br>
- 2 x Floppy <br>
- 6 x SATA <br>
Was £72.99 Inc. VAT
Only £67.99 inc VAT.
ORDER NOW
BeQuiet Efficient Power 600W '80 Plus Gold' Power Supply @ £64.99 inc VAT
The highly efficient '80 Plus Gold' power supply provide a typical 92% efficient unit to reliably and safely power your PC. Whether it is an office machine, a multimedia beast or a monster gaming rig this unit is ideal for all. With four +12V rails this can support all of the latest hardware including 2 GPU's as it has four PCI-Express power connectors and can power up to 6 SATA devices and and 4 molex powered devices.
- 120mm high-quality fan with a reliable silent bearing.
- Active clamp- + SR technology for very efficient and stable operation. Compatible with ATX 12V V2.31 and EPS 12V V2.92.
- Effective continuous output of 600W.
- Four independent 12V rails.
- Supports the latest generations of processors from Intel and AMD.
- Very efficient and power-saving operation
- 80PLUS Gold certification for the highest efficiency of up to 92%.
- ErP Lot 6 ready.
- Power consumption in stand-by mode <0.5W.
- Fulfils the requirements of the Energy Star 5.0 environmental and energy-saving guidelines.
- Suitable for multi-GPU operation: 4x PCI Express (2x 6+2-pin and 2x 6-pin).
- High compatibility with future as well as older components:
- 12V P8 connection (P4+4).
- Top safety and reliability
- Top protection for your components (OCP, OVP, UVP, OPP, OTP and SCP). Certified in accordance with international safety standards.
- Engineering, design and quality control in Germany
- 2-year manufacturer’s warranty
Was £69.99 Inc. VAT
Only £64.99 inc VAT.
ORDER NOW
Antec TruePower New Modular 650W '80 Plus Bronze' Power Supply @ £64.99 inc VAT
New features. Same true power. The TruePower New series by Antec offers users an advanced power supply solution, striking the perfect balance of reliability, efficiency and quality. With DC to DC voltage regulator modules, a 120mm PWM fan, and 80 PLUS® Bronze certification, TP-650 is the ideal solution for elite system builders and quality-minded enthusiasts alike.
- NVIDIA™ SLI™ - ready certified
- 80PLUS® Bronze Certified saves energy and lowers your electric bill
- DC to DC voltage regulator modules for greater system stability
- 120mm PWM fan runs up to 50% quieter than standard fans
- Advanced Hybrid Cable Management improves airflow and reduces clutter
- Double layer PCB optimizes cooling efficiency and allows for heavy duty components
- Universal Input and Active Power Factor Correction
- Supports dual GPUs and dual/quad core CPUs
- 4 +12V output circuits provide stable power
- ATX12V v2.3 and EPS12V v2.91
- 1 x 6 pin and 1 x 8 (6+2) pin PCI-E graphics card connectors for TP-550
- 2 x 6 pin and 2 x 8 (6+2) pin PCI-E graphics card connectors for TP-650, TP-750 and - Industrial grade protection
- Safety approval: UL, CUL, CE, CB, FCC Class B, TUV, CCC, C-tick, BSMI
- Dimensions: 86mm (H) x 150mm (W) x 150mm (D)
Was £69.99 Inc. VAT
ORDER NOW
Bit early for weekend deals? Some good prices though.
When are you going to pick a winner for the BitFenix Case competition by the way?
