****Round 13 of deals - Incredible Networking Deals****
Hi all. If you want a fantastic deal on a high quality Networking product, then look no further...
TP-Link Extended Range 54M wireless ADSL2 Router (TD-W8901G) @ £19.99 inc VAT
The TP-Link 54M Wireless ADSL2+ Modem Router TD-W8910G is a 3-in-1 device that combines the function of a high-speed DSL modem, wireless G access point, and 4-port Ethernet router. It supports the latest ADSL2/2+ standards to provide higher performance (up to 24Mbps downstream and 3.5Mbps upstream) and longer reach from your Internet Service Provider´ (ISP) Digital Subscriber Line Access Multiplexer (DSLAM).
With the TD-W8910G, you can create a wireless network to connect 802.11g/802.11b devices as well as a wired network to connect up to four 10/100 Ethernet devices.
- 3-in-1: ADSL2+ modem,4-port Ethernet router and wireless G access point
- Easily share ADSL connection with all office or home computers,wired or wirelessly
- Built-in firewall supporting IP address filtering, MAC address filtering and parental control
Was £22.99 inc VAT
Only £19.99 inc VAT.
ORDER NOW
TP-Link 300Mbps Wireless N ADSL2+ Modem Router (TD-W8960N) @ £34.99 inc VAT
3-IN-1 DEVICE:
The TP-LINK Wireless N ADSL2+ Modem Router (TD-W8960N) is an All-in-One device that combines the functions of a high speed DSL modem, a 4-Port 10/100Mbps NAT router and a wireless N access point. The TD-W8960N is designed to give you a one-stop solution to acquiring and sharing high speed Internet access over a wired/wireless network.
ACCESS HIGH-SPEED INTERNET:
Supporting the latest ADSL standards to provide higher performance (up to 24Mbps downstream and 3.5Mbps upstream) and longer reach from your Internet Service Provider (ISP) Digital Subscriber Line Access Multiplexer (DSLAM), the TD-W8960N brings with it much higher speed than a dial-up connection without tying up the phone line. This device also supports TR-069, which automatically updates the firmware and other settings when they become available from your ISP.
SHARING INTERNET THROUGH WIRELESS:
Complies with the IEEE 802.11n standard, users can create a wireless network and get up to 15X the speed and 5X the range of conventional 11g products. Now you can share your high-speed DSL Internet connection, photos, music, videos, printers, Network Attached Storage (NAS) and even the bandwidth consuming applications like HD video streaming wirelessly which can not be accommodated by 11g products, from anywhere in your entire home or even the yard ! The TD-W8960N supports QoS to enable smooth VoIP/IPTV streaming and lag-free online gaming.
- ADSL modem, NAT router and wireless N access point in one device provides one-stop networking solution
- Great for on-line gaming, making Internet call or even HD video streaming
Was £39.50 inc. VAT
Only £34.99 inc VAT.
ORDER NOW
TP-Link 150Mbps Wireless Lite N USB Adapter (TL-WN727N) @ £7.50 inc VAT
TP-LINK TL-WN727N is designed to provide a high-speed and unrivaled wireless performance for your computer. With a faster wireless connection, you can get a better Internet experience, such as downloading, gaming, video streaming and so on.
The TL-WN727N Lite N USB Adapter complies with IEEE 802.11g, and IEEE 802.11b standards. It can perfectly interoperate with all the 802.11n/g/b devices. The TL-WN727N´s auto-sensing capability allows high packet transfer rate of up to 150Mbps for maximum throughput.
- 150Mbps wireless transmission rate
- Provides two methods of operation: Infrastructure and Ad-Hoc
- Quick Secure Setup, complies with WPS for worry free wireless security
- Seamlessly compatible with 802.11b/g/n devices
Was £9.99 inc. VAT
Only £7.50 inc VAT.
ORDER NOW
TP-Link 8-port Unmanaged 10/100M Desktop Switch @ £7.99 inc VAT
TL-SF1008D 8-port 10/100Mbps Fast Ethernet Switch provides 8 10/100Mbps Auto-Negotiation RJ45 ports. All ports support Auto MDI/MDIX function, eliminating the need for crossover cables or Uplink ports. The Switch is Plug-and-Play and each port can be used as general ports or Uplink ports and can be simply plugged into a server, a hub or a switch, using straight cable or crossover cable.
The TP-LINK TL-SF1008D 8-port 10/100M Fast Ethernet Switch provides you with a low-cost, easy-to-use, high-performance, seamless and standard upgrade to improve your old network to a 100Mbps network. It will boost your network performance up to full duplex data transfer. Its wire-speed switching that forwards packets can be as fast as the speed that your network delivers those packets to them.
Was £9.99 inc. VAT
Only £7.99 inc VAT.
ORDER NOW
TP-Link 85Mbps Powerline Adapter Twin Pack (TL-PA101) @ £34.99 inc VAT
Establishing a powerline network requires at least two PLC adapters for the first time, the TP-LINK Powerline Ethernet Adapter Starter Kit is good for initially setup which including two same adapters -TL-PA101 2.0. It takes advantage of your home´s existing electrical wiring to create or extend a network. It allows users to turn any electrical outlet into a home network connection and share a broadband Internet connection, files and printers with PCs in different rooms at up to 85Mbps. Enjoy video, gaming, and Internet connection wherever you want it.
Twin Pack Design
The PLC connection is transmitting the data through the electric wire between two outlets, so it at least requires two PLC adapters pluged into the outlet to transform the data streaming. With twin pack design, the starter kit ensures to establish a powerline network for the first time.
NO New Wires
TP-LINK´s Powerline Ethernet Adapters can create or extend a network by using existing electrical wires throughout the building, easily extend your Internet access to any location around your home via a simple connection to a power outlet, with no need to drill through the walls and climb through the attic or cellar to install network cables.
No Configuration Required—Just Plug And Play
No configuration required, just connect your PC to a powerline adapter and plug it into a power outlet and instantly transform your household power grid into a fully functional network.
Was £39.99 inc. VAT
ORDER NOW
Was £22.99 inc VAT
ORDER NOW
3-IN-1 DEVICE:
Was £39.50 inc. VAT
ORDER NOW
Was £9.99 inc. VAT
Only £7.50 inc VAT.
ORDER NOW
Was £9.99 inc. VAT
Only £7.99 inc VAT.
ORDER NOW
Twin Pack Design
NO New Wires
Was £39.99 inc. VAT
ORDER NOW
