*****ROUND 13 OF WEEKEND DEALS - CASES****
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Coolermaster CM-690 II Lite Dominator Case - Black @ £58.99 inc VAT
The CM 690 II Lite raises the bar again, but with value for money, with practical improvements over the top-selling CM 690. The spacious mid-tower will keep enthusiasts happy with room for up to 3 vga cards, high-end CPU coolers, top or bottom mount water cooling radiator and 1.8"/2.5" drive adapter. It also features much improved airflow with oversized mesh and enough space for up to 10 fans. Maintenance will be a breeze with the tool-free drive bays, new cable management and CPU cooler retention hole. This model comes with a great looking window to showcase all your hardware.
- Dimensions: 214 x 511 x 528mm
- Motherboard Compatiblity: ATX, Micro-ATX, Mini-ITX
- Room for 120 x 240mm Radiator inside the top and bottom
- Includes SSD Adapter
- Cable management and CPU retaining holes for easy maintainence
- Support Tri-GFXs
- 4 x 5.25" Drive Bays
- 7 x 3.5" Drive Bays
- I/O Panel: USB2.0, 1 x eSATA, 2 x Audio
- Front Cooling: 1x 120 mm (17 dBA)
- Rear Cooling: 1x 120 mm (17 dBA)
- Top Cooling: 2 x 140 / 120 mm (optional)
- Bottom Cooling: 2 x 120 mm (optional)
- HDD Cage cooling: 1x 120 mm (optional)
Was £62.99 Inc. VAT
Only £58.99 inc VAT.
ORDER NOW
Lian Li PC-V352B Aluminium Cube Case - Black @ £126.99 inc VAT
Lian Li designers combine modern functionality with simple lines and a classic simple theme. The external sections combine with hair line brushed anodized finishing with a metallic look to create the traditional theme expected from Lian Li. PC-V352 is designed for your living room, it can fit a standard Micro ATX system into this tiny chassis and a standard ATX P/S2 power supply, whilst retaining great thermal performance. The fans are mounted with Lian Li’s anti-vibration fan mounting system; the rubber ring grommet absorbs the vibration, keeping the case silent, whilst also featuring Lian Li patented Anti-virbation HDD cage, which allow user to fit three 3.5" HDDs. It is easy to use, no tool required, simply using the special thrumb screw to secure the anti-vibration rubber ring to the HDD, and slide the HDD into the cage. PC-V352 equipped two 120mm intake fans, at the front to bring the cold air into the system. The fans cover the whole motherboard, and they can remove the heat fast.
Multi-media port connectors follow international specification standards, with one connector for easy installation. New USB3.0 ports x 2, e-SATA, Audio supports HD Audio. The dual design is for better compatibility options. Depending on your need, all I/O ports can be installed on the right or left side of the case, allow for easy access.
- Dimensions: (W) 280mm x (H) 275mm x (D) 400mm
- Front bezel Material: Aluminum
- Side Panel: Aluminum
- Body Material: Aluminum
- 5.25" Drive Bay: 2
- 3.5" drive bays: 4
- Motherboard: Micro ATX / Mini ITX
- System Fan (Front): 120mm Fan x 2
- System Fan (Top): None
- System Fan (Rear): 80mm Fan x 1
- I/O Ports: USB3.0 x 2 / e-SATA x 1 / HD Audio / SD Card Reader
Was £136.99 Inc. VAT
Only £126.99 inc VAT.
ORDER NOW
Antec P183 Super Midi Tower Case - Gun Metal Black @ £94.99 inc VAT
Building from a proven design, Antec introduces the P183, the next chapter in our Performance One Series enclosures. Dual chambers isolate the power supply and CPU into separate cooling zones, with up to five configurable fans for unsurpassed cooling. Three-layer, sound-deadening panels dampen noise even in the most demanding systems, ensuring quiet operation. The original P180 was a breakthrough in case design, and now the P183 carries on the tradition, ushering in the latest standards for cooling and quiet.
- 11 Drive Bays
- External 4 x 5.25”; 1 x 3.5”
- Internal 6 x 3.5” for HDD
- 7 Expansion Slots
- PS/2 size power supply or the unique Antec CP-850
- Cooling System:
- 1 rear (standard) 120mm x 25mm TriCool Fan
- 1 top (standard) 120mm x 25mm TriCool fan
- 1 lower chamber (optional) 120mm x 25mm
- 1 front (optional) 120mm fan
- 1 middle (optional) 120mm fan
- Divided upper and lower chamber structure: the power supply resides in a separate chamber with dedicated cooling from a 120mm fan to isolate heat from the system and lower system noise
- Innovative three-layer side panel and front door (aluminium, plastic, aluminium) dampens system generated noise, making this one of the quietest cases available
- Double-hinged door designed to open up to 270º for easier system integration
- 0.8mm cold rolled steel throughout the majority of the chassis to enhance durability
Was £99.99 Inc. VAT
Only £94.99 inc VAT.
ORDER NOW
Coolermaster Storm Sniper All Black Window Edition Case - Black @ £112.99 inc VAT
CM Storm Sniper Black Edition mesh version with Window - the best gaming chassis in the world just got better, with an all black interior and 2.5" HDD/SSD support. Reinforced by CM Storm's revolutionary Storm Tactics, with its dedicated focus on Strength, Security, and Control, the Sniper Black Edition stands ready to mobilize your next gaming session and fully back up your skills! Strength - undeniable material strength and unprecedented airflow from three huge 200mm fans. Security - the groundbreaking StormGuard™ security system efficiently protects your gaming peripherals from theft.
Control - the unique control center offers convenient control over fan speeds and lights, while the sturdy carrying handles let you decide the place for your next battle. Sniper also has plenty of flexibility for water cooling enthusiasts, with radiator support and two positions for routing tubes (top 26mm and bottom 18mm).
- All black interior coating and side window to show off your gear!
- Solid Bridge included for full 2.5" SSD/HDD support!
- Unprecedented airflow from two huge 200mm blue LED fans.
- StormGuard™ - groundbreaking security system for safeguarding your gaming peripherals.
- Next generation control panel for tuning your lights and fans.
- Convenient handle and foot stand for fast and efficient mobilization and relocation.
- Dimensions: (D)566.6 x (W)254.6 X (H)551 mm
- M/B Type: Micro-ATX/ATX
- 5.25" Drive Bay: 5 Exposed (without the use of exposed 3.5" Drive Bay)
- 3.5" Drive Bay: 5 Hidden
- 1 Exposed (converted from one 5.25" Drive Bay)
- 2.5" Drive Bay: 1 Hidden (Converted from one 3.5" Drive Bay)
- Front Cooling: 200x30mm Blue LED Fan x 1 (500 - 1000rpm, 17 - 23 dBA)
- Top Cooling: 200x30mm Blue LED Fan x 1 (500 - 1000rpm, 17 - 23 dBA) can be swapped for two 120mm fans or 120x240mm Radiator)
- Rear: 120x25mm Standard Fan x 1 (1200rpm, 17 dBA) (can be swapped for 90mm fan or 80mm fan)
- Bottom: Supports 140mm Fan x 1 or 120mm Fan x 1 w/ Dust Filter (optional)
- Expansion Slots: 8
- I/O Panel: USB2.0 x 4; IEEE1394 x 1; eSATA x 1; Mic x 1; HD Audio+AC’97 x 1
- Included Accessories: StormGuard™ - groundbreaking security system for safeguarding your gaming peripherals. Solid Bridge - 1.8" or 2.5" to 3.5" mounting bracket for SSD or HDD.
- 2 Year limited warranty
Was £119.99 Inc. VAT
Only £112.99 inc VAT.
ORDER NOW
Akasa Freedom Xone Case - Black @ £39.99 inc VAT
Akasa Freedom products are designed to unleash the performance of your system. Freedom Xone is a cutting edge midi tower case delivering superb cooling. A “Black is Black” case with sleek black interior. The striking appearance of the mesh front panel with pure white illumination provides constant airflow.
The cool black chassis uses zoned thermal management including base mounted PSU and smart cable management giving that clean tidy system. All round easy access including rear entry to the motherboard for heatsink backplate fitting and tool free HDD installation makes system building a breeze. Full size hi-performance VGA cards are accommodated and kept cool with side panel ventilation.
- Dimensions: (H) 445 x (W) 200 x (D) 482mm
- Compatible motherboard types: MicroATX & ATX
- Full Black Interior
- 6 x 3.5" Drive Bays
- Front Cooling: 120 x 120 x 25mm, white LED, 1200RPM (front)
- Top Cooling: 140 x 140 x 25mm, black, 1000RPM (top)
- I/O Ports: 2 x USB2.0, 1 x eSATA, 1 x HD Audio
Was £42.99 Inc. VAT
Only £39.99 inc VAT.
ORDER NOW
Fractal Design Define R3 Midi Tower Case - Titanium Grey @ £81.99 inc VAT
The Define R3 case is reaching new heights in combining stylish, contemporary design with maximum functionality and noise absorbing features. The minimalistic, yet stunning front panel design, fitted with noise absorbing material on the inside, creates an aura of exclusivity. The patent pending feature ModuVent™, in which you can choose whether to have side and top panels open or not, makes the case appealing for users seeking optimal silence, as well as the performance hungry ones. The sleek black interior is matched with pre-fitted, dense noise absorbing material on the side panels, efficiently absorbing noise and vibrations. You can fit an astonishing total of eight(!) hard drives into this case, using the user friendly HDD-trays. All painted in a nice white color and using black silicone mounts. PSU is mounted in the bottom of the case, with a convenient pull-out filter beneath it. Are you one of those users always ending up with a case full of tangled cables? No more. The Define R3 offers a convenient and good looking way of hiding them away. The motherboard has rubber covered holes in which you can easily route the cables behind the motherboard.
- Stunning front panel design
- Patent pending ModuVent™ design, allowing the user to either have optimal silence or optimal airflow
- Pre-fitted with dense, noise absorbing material
- 8 white painted HDD-trays, with silicone mounting
- A total of 7 fan slots (2x120mm in front, 2x 120/140mm in top, 1x120mm in back, 1x 120/140mm in side panel, 1x 120/140mm in bottom)
- 2x 120mm Fractal Design 120mm fans included
- Fan controller for 3 fans included
- Easily removable front fan filters with clip-on holders for 120mm fans
- Supports graphic card lengths up to circa 290mm and CPU coolers with height of maximum circa 165mm
- 1 rear Fractal Design 120mm @ 1350rpm included
- 1 front Fractal Design 120mm @ 1350rpm included
- 1 front 120mm fan (optional)
- 1 bottom 120mm/140mm fan (optional)
- 1 side panel 120mm/140mm fan (optional)
- 2 top 120mm/140mm fan (optional)
- Case size (WxHxD): 207.4 x 440 x 521.2mm
Improvements from R2
- Improved air flow with updated fans
- Improved noise absorbing material
- Bigger hole in M/B plate for mounting of CPU Coolers
- Improved cable routing possibilities
- Reset button, located behind the front panel door
- Many small quality improvements, including improved scratch resistant coating
Was £89.99 Inc. VAT
Only £81.99 inc VAT.
ORDER NOW
Crikey those Lian Li V series cases are expensive now. I'm sure the old V350 used to be about £70-£80 at one point. I know the new one is better though.
Some good reductions there, bringing the Akasa case to sub £40 makes it a much more attractive proposition for a budget build.
