*****Round 16 of Deals - Cases*****
17 Oct 2002
Stoke
Antec Dark Fleet Series DF85 Gaming Enclosure - Black @ £134.98 inc VAT
Time to build a killer rig? Turn to Antec. The DF-85 is the gaming case re-envisioned, with all the award-winning build quality that made Antec cases famous and plenty of airy, wide-open expandability with 14 total drive bays and 7 expansion slots. Fleet-Release™ front drive bays allow swift customization of front fan and drive configurations and easy access to tool-less, washable fan filters. A top-mounted hot-swappable SATA (SSD-compatible) drive bay plus Fleet-Swap™ SATA drive interfaces offer blazing fast throughput with superb convenience. With pioneering design and world-first conveniences, the Dark Fleet DF-85 is the case of choice for your next flagship.
- Three Fleet-Release™ access doors open separately for convenient entry to drives
- Three washable fan filters allow for easy cleaning
- Top 2.5” hot-swap SATA (SSD-compatible) drive bay
- Bottom-mounted power supply isolates heat
- Mounts either a standard size power supply or an Antec exclusive CP Series power supply
- Lockable access doors ensure security
- CPU cutout allows for easy installation of CPU coolers
- 14 drive bays
- Up to 9 x internal 3.5”
- 3 x external 5.25”
- 4 x external 3.5” Fleet-Swap™ drives (position changeable)
- 1 x external top 2.5” hot-swap SATA drive bay
- 1 x internal bottom-mounted 2.5” SSD drive
- Advanced cooling system
- 2 x top 140mm TwoCool™ fans
- 2 x rear 120mm TwoCool™ red LED fans
- 3 x front 120mm red LED fans with speed control knobs
- 1 x side 120mm fan to cool graphics cards (optional)
- Water cooling capable
- 7 expansion slots to support multiple graphics cards
- Maximum graphics card size: 12.5” / 318 mm
- Cable management ties help keep your case tidier
- Stylish blacked-out interior
- Windowed side panel
- Front ports
- 1 x USB 3.0
- 3 x USB 2.0
- Audio (AC’97 and HDA compatible) In and Out
- Motherboards: Mini-ITX, microATX, Standard ATX
- Power supply not included
- Weight: 26.3 lb / 11.3 kg
- Dimensions: 596mm (H) x 213mm (W) x 505mm (D)
Was £139.99 Inc. VAT
Only £134.98 inc VAT.
ORDER NOW
Antec 1200 Twelve Hundred Ultimate Gaming Case - Black @ £114.99 inc VAT
The Antec Twelve Hundred is the evolution of the best-selling Nine Hundred, expanding on its award-winning design with even more cooling, capacity, and convenience. The Twelve Hundred is incredibly robust, with 12 drive bays, 7 expansion slots, and space for even the largest graphics cards. To keep the most demanding systems nice and cool, the Twelve Hundred boasts an unprecedented cooling system, with a top mounted 200mm blue LED fan, two rear blue LED 120mm fans, and three front blue LED 120mm fans to cool the HDD cages. Factor in convenient features like front mounted USB, eSATA, and HD audio ports, and the Twelve Hundred obliterates the competition.
- 12 Drive Bays
- 7 expansion slots
- No power supply included
- Motherboard: Up to standard ATX
- Top mounted I/O ports for easy access
- Perforated front bezel for maximum air intake
- Washable air filters reduce dust build up in your system
- Convenient top accessory tray for a personal media player
Was £124.98 Inc. VAT
Only £114.99 inc VAT.
ORDER NOW
Corsair Obsidian 800D Full Tower Case - Black @ £204.99 inc VAT
The Obsidian Series 800D is built to last through years of motherboard, power, memory, cooling, and component upgrades.<br>
The steel structure has a matte black coating both inside out and is finished with a brushed aluminum faceplate for a professional look that’s both serious and awe-inspiring. A windowed side panel makes it easy to show off your work.
The power supply compartment, main compartment and the SATA bays each have dedicated cooling subsystems to prevent heat buildup.<br>
A dust-filtered 140mm fan draws in cold air at the bottom of the chassis and exhausts it at the rear and top. This clever design forces fresh air directly over the graphics card and CPU. The SATA hot-swap bays are cooled by a separate 140mm fan which vents from the chassis via a sealed chamber and prevents the heat generated by the drives from entering the main compartment. The power supply compartment has its own dedicated intake and exhaust, also isolated from the main compartment.
Need even more cooling performance? The Obsidian Series 800D has pre-drilled support for top-mounted single, dual, and triple radiators, or up to three additional 120mm fans.
A four-drive SATA hot-swap drive bay sits in the front of the case, making it easier to install or swap hard drives on the fly. A unique cable routing system virtually eliminates cable clutter that can impede airflow. The tool-free design allows for easy entry, easy access, and quick installation of 5.25” drives.
- Four easily accessed hot-swap drive bays
- Removable CPU backplate panel for easy heatsink installation
- Isolated cooling zones prevent heat buildup
- Unique cable routing holes guarantee a clean and clutter-free installation
- Three fans included, with the ability to add four more 120mm fans
- Tool-free optical drive installation makes building a system faster than ever
- Two year warranty with Corsair’s world-class customer service and technical support
- Dimension: 609mm X 609mm X 229 mm
- 5 x 5.25" Drive Bays
- 4 x 3.5" SATA Hot Swappable Bays
- 2 x 3.5" Internal Bays
- Cooling: 3 x 140mm fans (included)
- Cooling: 4 x 120mm fans (optional)
- Front I/O: 4x USB 2.0, 1x FireWire, 2x Audio
Was £219.98 Inc. VAT
Only £204.99 inc VAT.
ORDER NOW
Lian Li PC-A05NB Aluminium Mini-Tower Case - Black @ £68.98 inc VAT
The PC-A05N was designed specificially for users with limited space but still require the best performance system available. The mini-tower A05N supports full ATX motherboards and powerful graphics cards. The most unique feature of this case is the Power Supply mounting point - you fit the PSU at the front of the case at the base. allowing the case to be shorter amd smaller. Quality and features are not comprimised either, even in such a small case, the patented anti vibration HDD cage, a 120mm exhaust fan and the much loved I/O ports, which are typical of a Lian Li case, are all still present.
- Mini Tower Chassis
- Front bezel Material :Aluminum
- Side Panel :Plain
- Body Material :Aluminum
- 5.25" drive bay (External) : 2
- 3.5" drive bay (External) : 1
- 3.5" drive bay (Internal) : 3
- Expansion Slot : 7
- Motherboard : ATX, M-ATX
- System Fan (Front) : 12cm Ball-Bearing Fan x 1 (1500RPM)
- System Fan (Rear) : 12cm Ball-Bearing Fan x 1 (1500RPM)
- I /O Ports : USB2.0 x2, IEEE1394 x1, HD+AC97 audio
- Dimensions : 210mm x 381mm x 490mm (W x H x D)
Was £72.99 Inc. VAT
Only £68.98 inc VAT.
ORDER NOW
Damn, was hoping for a 932. Never mind...
Great deal on the Lian Li I think. If I had money for a desktop MATX rig that would look amazing on my desk! But I prefer big, modded HAF 932's on my desk!
hot damn... these are some beautiful cases.... already got the antec 902 so not going to rush out and buy another case just yet :( pity the people that make cases, can`t make them smaller lol.....
antec 300 is very cheap for what it is!!
Id get the obsidian out of them. Very nice case, check out the youtube reviews of it. Such a well thought out case...
The LL is only reduced by £4 how is that a great deal???
Maybe I worded it all wrong, im sure there are nice folk like you out there who will like it, I suppose each to their own fits perfectly. But for me personally I just cold not have that as my PC case. Maybe a few dremel modifications could change it for me.
wasn't commenting on the looks of the LL at all, I was simply suggesting £4 discount as a percentage of the cost didn,t represent a "great deal"
wonder if wires are crossed somewhere?
Yeah definately wires crossed here, I was on about the Antec Darkfleet case. The lian li is a very handsome case that I'd have to think very hard before even contemplating taking a dremel to. As for the great deal on it, i agree, £4.00 aint much of a deal.
