- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Right for round 2 we have a selection of complete watercooling kits:-
Corsair H50-1 High-Performance CPU Watercooler (Socket LGA775/1156/1366/AM2/AM3) @ £59.98 inc VAT
The Corsair Hydro Series™ H50 CPU Cooler gives you the power of liquid cooling in a compact, easy to install package. You get superior cooling for higher overclocking performance without the complexity of traditional liquid-cooling systems.
The Hydro Series H50 goes head-to-head with top of the line heatsinks, but maintains the near silence of liquid cooling for annoyance-free cooling performance. Due to its compact form factor, the H50 is the ideal solution for any case with a 120mm fan mount, even small form factor cases that prevent the installation of traditional heatpipe based air coolers. So whether you want world-class cooling, lower noise levels than your current CPU cooler, or something that fits in your small form factor case, the closed-loop Hydro Series H50 takes your CPU’s temperature to new lows and takes up less room doing it.
- Pre-filled, closed-loop system is easy to install
- Copper CPU cooling plate for maximum cooling performance
- Integrated pump and reservoir is sealed for zero maintenance and improved leakage protection
- Large 120mm radiator for fast heat dispersion
- High-efficiency, low-noise 120mm fan for drawing cool air across the radiator
- Two-year warranty
Was £62.99 Inc. VAT
Only £59.98 inc VAT.
ORDER NOW
CoolIT Eco A.L.C. CPU Watercooler (Socket AM2/AM2+/AM3/LGA775/LGA1156/LGA1366) @ £49.98 inc VAT
A revolutionary leap in design delivers industry leading realiability, performance and value.
The ECO Advanced Liquid Cooling (A.L.C.) System is an elegantly engineered ultra low profile thermal solution positioned at an economical price point. CoolIT's engineers have focused on offering a superior propriatory cooling technology that delivers the ultimate performance in a compact design. The whisper quiet ECO cooler is widely compatible with the majority of pc cases featuring a 120mm fan and can beinstalled in 3 easy steps. CoolIT's selection and design of each componenthas been scrutinized to ensure the ECO provides the industry leading performance and reliability resulting in the ultimate maintenance free cooling solution.
- CoolIT's compact pump runs quietly whilst maintaining an optimal flow rate
- CoolIT engineered for high heat disapation at low fan speeds reuslting in efficient, quiet operation
- A Micro-Channel Fluid Heat Exchanger that lets you reach the maximum potential of your CPU overclock
- A pre-filled, factory sealed, liquid loop of carefully chosen components offers years of worry free cooling
- CoolIT's pro advanced thermal compound is pre applied for easy installation
- Extremely easy to install retention for Intel 775, 1156, 1366, and AMD, AM2, AM2+, AM3 Sockets
- Two-year warranty
Was £53.99 Inc. VAT
Only £49.98 inc VAT.
ORDER NOW
CoolIT Vantage Liquid CPU Cooler (LGA775/LGA1156/LGA1366/AM2/AM2+/AM3) @ £104.99 inc VAT
Vantage ALC provides an elegantly engineered cooling solution with an advanced control system that monitors temperature and auto-regulates the fan to ensure the highest degree of efficiency and minimum acoustic noise with continuous protection of the CPU. The innovative LCD screen enables user-selectable control profiles with a display capable of 6 colors and 4 orientation settings. The Vantage A.L.C. provides superior performance and industry leading reliability with a feature set unparalleled by any single cooling product on the market. The Vantage ALC is upgradable with CoolIT's Maestro software control platform, coming Summer 2010, that offers features thus far unseen in the PC market.
- Universal Retention System
- Quiet, compact, long life Ceramic bearing CFF1 pump
- CoolIT Systems low toxicity with anticorrosion/anti fungal additives
- Custom engineered for low noise high heat dissipation
- Fan Speed: 1100 - 2,500 RPM (low to high regulation)
- CoolIT Systems Pro A.T.C. (Advanced Thermal Compound)
- Three standard 3 or 4 pin fan headers that can auto detect a variety of third-party fans.
- Integrated Red-Green LED as well as an external RGB LED header and one temperature sensor header allowing for remote temperature detection.
- Three cooling performance modes quiet, performance, and full.
- CoolIT 2 Year Manufacturer Warranty
Was £114.99 Inc. VAT
Only £104.99 inc VAT.
ORDER NOW
- Two-year warranty
Was £62.99 Inc. VAT
ORDER NOW
- Two-year warranty
Was £53.99 Inc. VAT
ORDER NOW
ORDER NOW
