- 11 Dec 2005
- Cheshire
Got a load of sweet overclocked bundles deals for you guys this weekend. First off the Radon Intel i5 760 4.00GHz overclocked bundle featuring the Gigabyte P55-USB3 motherboard with USB 3.0 technology and an immense 4.00GHz overclock.
Secondly we have the AMD equivilant the Radon AMD Phenom X4 3.60GHz overclocked bundle at an amazing £269.99 inc VAT. Featuring a 3.60GHz overclock with quad core processing, this makes the pefect centre to a solid gaming build. Get these quick guys as the promotion only lasts for this weekend!
Radon Intel Core i5 760 2.80GHz @ 4.00GHz Overclocked Bundle @ £372.99 inc VAT
Designed by experts the "Radon Intel Core i5 760 Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.00GHz overclock has the processing power and speed unseen at this price point ever before. The "Radon Intel Core i5 760 Bundle" will accelerate your computer experience into the next level.
Why You Should Buy This Bundle?
- A solid, optimised 4.00GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 4GB of Dual Channel DDR3 memory delivers unsurpassed bandwidth
- SATA 6Gb/s and USB 3.0 compatible offering lightning fast transfer speeds
Bundle Specification
- CPU: Intel Core i5 760 2.80GHz @ 4.00GHz
- Motherboard: Gigabyte P55-USB3 Intel P55 (Socket 1156) DDR3 Motherboard
- RAM: Corsair Dominator 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
- Cooler: Akasa Nero S CPU Cooler (Upgrade options available)
- Artic Silver 5 Thermal Compound
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Note - All Bundles are built and installed on demand and usually ship within 48 hours of the order being placed. Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Was £392.99 Inc. VAT
Only £372.99 inc VAT.
ORDER NOW
Radon AMD Phenom II X4 955 3.20GHz @ 3.60GHz Overclocked Bundle @ £269.99 inc VAT
Designed by experts the "AMD Phenom II X4 955 Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 3.60GHz overclock has the processing power and speed unseen at this price point ever before. The "AMD Phenom II X4 955 Bundle" will accelerate your computer experience into the next level.
- A solid, optimised 3.60GHz overclock profile provides outstanding processing performance
- 4GB of Dual Channel DDR3 memory delivers unlimited bandwidth
- Quad Core processing performance
- CPU: AMD Phenom II X4 955 3.20GHz @ 3.60GHz
- Motherboard: Gigabyte GA-880GM-UD2H AMD 880G (Socket AM3) DDR3 Motherboard
- RAM: Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
Service Package
Was £289.99 Inc. VAT
Only £269.99 inc VAT.
ORDER NOW
Service Package
ORDER NOW
Service Package
ORDER NOW
