** ROUND 2 OF WEEKEND DEALS - POWER SUPPLIES **
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
OCZ ZS Series 550W '80 Plus Bronze' Power Supply @ £49.99 inc VAT
The OCZ ZS Series PSU is the superlative solution for driving today's value oriented gaming systems, and can power both NVIDIA® SLI™ and ATI CrossFire™ modes. Enthusiast-grade yet designed with gamers and modders in mind, this PSU is stable, robust, and sports a sleek look and compact form factor. Kept ultra-cool with a load-controlled 135mm fan, the OCZ ZS Series PSU was engi-neered to be the quietest PSU available in its class, elimi-nating distracting noises from your PC. Highly efficient, featuring up to 86.72% efficiency at typical load and up to 83% at full load, this leading-edge power supply remains rock solid and powerful while retaining superior efficiency under load.
This PSU is backed with OCZ’s 3-year “power swap” warranty, the OCZ ZS Series PSU gives you the ultimate power and peace of mind to ensure the stability, low noise, optimized air flow, and efficiency of your gaming system.
- OCZ PowerWhisper™ Technology
- Internal 135mm ball-bearing fan
- Can power SLI™ and CrossFire™ GPU configurations
- 150 x 160 x 86mm (W x L x H)
- ATX12V v2.2 and EPS12V
- 86% Efficiency (Typical Load)
- Overvoltage/Overcurrent/Short-Circuit protection
- Active PFC
- MTBF: 100,000 hours
- 3 year warranty backed by OCZ’s exclusive PowerSwap™ replacement program.
Was £59.99 Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
OCZ ZS Series 650W '80 Plus Bronze' Power Supply @ £59.99 inc VAT
- Active PFC
Was £69.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
OCZ ZX Series 850W '80 Plus Gold' Modular Power Supply @ £124.99 inc VAT
The ZX Series is the unsurpassed solution for driving today's Enthusiast and gaming systems. It has the ability to easily power both NVIDIA® SLI™ and ATI CrossFire™ modes, supporting even the most power hungry GPUs with multiple GPU configurations. Industrial-grade yet designed with enthusiasts, gamers and modders in mind, this PSU is stable, robust, and sports a sleek look and the most compact form factor of its class.
Kept ultra-cool with a load-controlled ultra quiet 140mm fan, the ZX Series was engineered to be the quietest PSU available and eliminate distracting noises from your PC. Highly efficient, featuring up to 92% efficiency at typical load and up to 89% at full load, this leading-edge power supply remains rock solid and powerful while retaining superior efficiency under load. The OCZ ZX Series provides universal Input and Active PFC (Power Factor Correction) to effectively regulate input voltage across worldwide power grids and maintain an economical, stable supply of power.
Backed with OCZ’s 5-year “power swap” warranty, the OCZ ZX Series PSU gives you the ultimate power and peace of mind to ensure the stability, low noise, optimized air flow, and efficiency of your gaming system.
- 850W Continuous power
- Ultra quiet 140mm ball-bearing fan
- +12VDC @ 70A Single Rail Design
- SLI™ and CrossFire™ support
- Fully modular cable management system
- 150 x 175 x 86mm (W x L x H)
- 80-Plus Gold Certified
- 92% Efficiency (Typical Load)
- Active PFC
- 5 year warranty backed by OCZ's exclusive
- PowerSwap Warranty replacement program.
- 20+4 pin ATX
- Dual 4+4 pin CPU
- 4 x PCIe 6+2 pin
- 12 x SATA
- 9 x Molex
- 1 x Floppy
Was £134.99 Inc. VAT
Only £124.99 inc VAT.
ORDER NOW
OCZ ZX Series 1000W '80 Plus Gold' Modular Power Supply @ £139.99 inc VAT
- 1000W Continuous power
- +12VDC @ 83A Single Rail Design
- Active PFC
- 20+4 pin ATX
- Dual 4+4 pin CPU
- 6 x PCIe 6+2 pin
- 12 x SATA
- 9 x Molex
- 1 x Floppy
Was £149.99 Inc. VAT
Only £139.99 inc VAT.
ORDER NOW
OCZ ZX Series 1250W '80 Plus Gold' Modular Power Supply @ £159.98 inc VAT
The ZX Series is the unsurpassed solution for driving today's Enthusiast and gaming systems. It has the ability to easily power both NVIDIA® SLI™ and ATI CrossFire™ modes, supporting even the most power hungry GPUs with up to triple GPU configurations. Industrial-grade yet designed with enthusiasts, gamers and modders in mind, this PSU is stable, robust, and sports a sleek look and the most compact form factor of its class.
- 1250W Continuous power
- +12VDC @ 104A Single Rail Design
- Active PFC
- 20+4 pin ATX
- Dual 4+4 pin CPU
- 6 x PCIe 6+2 pin
- 12 x SATA
- 9 x Molex
- 1 x Floppy
Was £169.99 Inc. VAT
Only £159.98 inc VAT.
ORDER NOW
OCZ ModXStream Pro 500w Silent SLI Certified Modular Power Supply @ £44.99 inc VAT
The ModXStream Pro Series is the superlative solution for driving today's gaming systems, and can power both NVIDIA® SLI™ and ATI CrossFire™ modes. Professional-grade yet designed with gamers and modders in mind, this PSU is stable, robust, and sports a sleek look and compact form factor. Kept ultra-cool with a load-controlled 140mm fan, the ModXStream Pro was engineered to be the quietest PSU available and eliminate distracting noises from your PC. Highly efficient, featuring up to 86% efficiency at typical load and up to 82% at full load, this leading-edge power supply remains rock solid and powerful while retaining superior efficiency under load.
The OCZ ModXStream provides Universal Input and Active PFC (Power Factor Correction) to effectively regulate input voltage across worldwide power grids and maintain an economical, stable supply of power. Available in configurations ranging from 400W to 700W and backed with OCZ’s 3-year “power swap” warranty, the OCZ ModXStream Pro gives you the ultimate power and peace of mind to ensure the stability, low noise, optimized air flow, and efficiency of your gaming system.
- up to 86% Efficiency
- Overvoltage/OverPower/Short-Circuit protection
- (.99)Active PFC
- MTBF: 100,000 hours @ 25C
- 1 x 20/24-pin ATX
- 1 x 8-pin CPU
- 1 x 4-pin CPU
- 1 x 6-pin PCI-E
- 1 x 6+2-pin PCI-E
- 4 x Peripheral
- 2 x Floppy
- 6 x SATA
Was £49.99 Inc. VAT
Only £44.99 inc VAT.
ORDER NOW
OCZ ModXStream Pro 600w Silent SLI Certified Modular Power Supply @ £59.99 inc VAT
- (.99)Active PFC
- 1 x 20/24-pin ATX
- 1 x 8-pin CPU
- 1 x 4-pin CPU
- 1 x 6-pin PCI-E
- 1 x 6+2-pin PCI-E
- 4 x Peripheral
- 2 x Floppy
- 6 x SATA
Was £66.99 Inc. VAT
ORDER NOW
OCZ ModXStream Pro 700w Silent SLI Certified Modular Power Supply @ £68.99 inc VAT
- (.99)Active PFC
- 1 x 20/24-pin ATX
- 1 x 8-pin CPU
- 1 x 4-pin CPU
- 1 x 6-pin PCI-E
- 1 x 6+2-pin PCI-E
- 4 x Peripheral
- 2 x Floppy
- 6 x SATA
Was £73.99 Inc. VAT
Only £68.99 inc VAT.
ORDER NOW
I think you've got me with this one,
whats the cable length like on the OCZ ZX series 1250w? I have a cooler master cosmos pure and have to extend my cables for 4 and 8 pin CPU connectors on my modxstream 700w
I would like my case nice and tidy and ready if I went for SLI/XFIRE 3 high end graphics cards
The cable length on the ZX is way longer, and better than the modxstream by far. The mod X Stream cable length is very poor to be honest.
It is fine, we have a OcUK staff member who uses that exact PSU in a Fractal Design XL case in his PC at home. The XL is the big brother of the R3.
Nice deals on the ZX PSUs. 125 for a gold rated fully modular 850W, 140 for a 1250W - excellent! They are pretty much the best on the market in those wattage ranges, similar or better quality than the Corsair AX series. Very quiet too.
As mentioned above I have the 850W in my Fractal XL, no real issues with cable lengths though I have Bitfenix extensions anyway just for the looks. The cables are certainly a lot longer than OCZ's usual.
Would have to say the Antec HCP is better than the zx for 1.2kw range, but apart from that I would agree :)
