*****ROUND 4 OF WEEKEND DEALS- NETWORKING*****
5 Jul 2010
TP Link are One of the worlds largest manufacturers of Networking Products.
Why buy TP Link :-
- 3 Years Warranty on all Products
- UK Technical Support - 24/7
- Global pressence.
- Manufacturing netwroking Products for over 10 years and are building a new £8 million Plant in the far east.
We are also offering one of the TP Link products at cost, while stocks last.
TP-Link 10/100M PCI Network Adapter @ £5.29 inc VAT
The TP-LINK TF-3239DL Fast Ethernet Adapter is a highly integrated and cost-effective Fast Ethernet Adapter that provides 32-bit performance, PCI bus controller, and full compliance with IEEE 802.3 10Base-T, IEEE 802.3u 100Base-TX specifications and IEEE 802.3x Full Duplex Flow.
TF-3239DL keeps low cost and eliminates usage barriers. It is the easiest way to upgrade a network from 10 to 100Mbps. Supports both 10Mbps and 100Mbps network speed both in Half-Duplex and Full-Duplex transfer modes, using Auto-Negotiation technology to detect the network speed. It also can be widely used in most modern Operating System. For Windows Me/2000/2003/XP integrates the right driver, TF-3239DL is really a plug-and-play device
Only £5.29 inc VAT.
ORDER NOW
TP-Link 150Mbps High Gain Wireless USB Adapter (TL-WN722NC) @ £12.91 inc VAT
The TP-LINK TL-WN722N Wireless High Gain USB Adapter allows you to connect a desktop or notebook computer to a wireless network and access high-speed Internet connection. Using AlignTM 1-stream technology based on 802.11n technology, TL-WN722N provides a better wireless signal than existing wireless 802.11g technology. Most of all, equipped 4dBi detachable antenna can remarkably boost your signal range and speed. Now you can get a better Internet experience, such as downloading, gaming, video streaming and so on.
HIGH GAIN DESIGN
With powerful 4dBi detachable antenna, the TL-WN722N remains excellent performance in the long range and bad environment, it can receive signal from wireless base even separated by 2 floors.
QUICK SECURE SETUP
QSS or Quick Security Setup is a handy feature that allows users to almost instantly setup their security simply by pressing the QSS button on the wireless adapter, it automatically establishes a WPA2 secure connection, instantly protecting your network.
TL-WN722NC equipped with the USB cradle and 1.5m extension cable, which allow you to save USB port space, and extend the USB connection length up to 5 feet, making it more convenient to plug the USB device in & out of the USB socket. Its elegant and stylish design is suitable for home deployment and will even improve the look of your home and office.
Why AlignTM technology is better?
AlignTM technology is announced by Atheros Communications, Inc, which is a leading developer of advanced semiconductor system solutions for wireless and wired communications. Based on the IEEE draft 802.11n 1-stream specification, the single-stream feature enables a new class of Wi-Fi® devices that deliver performance enhancements over the existing 802.11g technology, at comparable price points. Align solutions are also forward compatible to higher-performance, multi-stream, MIMO-based 802.11n - providing the optimal upgrade path for value-class WLAN products. Consumers who move from 802.11g to products based on Align 1-stream technology will experience enhanced performance in their home networks.
- 150Mbps wireless transmission rate
- Provides two methods of operation: Infrastructure and Ad-Hoc
- Quick Secure Setup, complies with WPS for worry free wireless security
- Supports 64/128-bit WEP, complies with 128 bit WPA standard(TKIP/AES), supports MIC, IV Expansion, Shared Key Authentication, IEEE 802.1X
- 4dBi omni-directional antenna detachable
- Supports Windows 2000/XP/Vista/7
- Seamlessly compatible with 802.11b/g/n devices
Equipped with an elegant and stylish USB Cradle for flexible deploymen
Only £12.91 inc VAT.
ORDER NOW
TP-Link 85Mbps Powerline Adapter Twin Pack (TL-PA101) @ £34.99 inc VAT
Establishing a powerline network requires at least two PLC adapters for the first time, the TP-LINK Powerline Ethernet Adapter Starter Kit is good for initially setup which including two same adapters -TL-PA101 2.0. It takes advantage of your home´s existing electrical wiring to create or extend a network. It allows users to turn any electrical outlet into a home network connection and share a broadband Internet connection, files and printers with PCs in different rooms at up to 85Mbps. Enjoy video, gaming, and Internet connection wherever you want it.
Twin Pack Design
The PLC connection is transmitting the data through the electric wire between two outlets, so it at least requires two PLC adapters pluged into the outlet to transform the data streaming. With twin pack design, the starter kit ensures to establish a powerline network for the first time.
Compact, Stylish, Clutter-free
Compared with TP-LINK´s previous 85Mbps powerline adapter, the new TL-PA101 adopts a much more compact and stylish exterior to blend with its surroundings. Using existing electrical wires the adapter does away with the hassle of hiding messy Ethernet cables underneath rugs and tape.
NO New Wires
TP-LINK´s Powerline Ethernet Adapters can create or extend a network by using existing electrical wires throughout the building, easily extend your Internet access to any location around your home via a simple connection to a power outlet, with no need to drill through the walls and climb through the attic or cellar to install network cables.
No Configuration Required—Just Plug And Play
No configuration required, just connect your PC to a powerline adapter and plug it into a power outlet and instantly transform your household power grid into a fully functional network.
Advanced Multimedia Streaming
TP-LINK´s Powerline Adapter is an ideal solution for connecting computers, game consoles, network attached storage and any Ethernet-enabled devices to your home network or the Internet. Up to 85Mbps high-speed transfer rates as well as advanced QoS technology make it possible to transmit video in DVD quality. No more long waits while sending big files or while carrying out heavy-weight data backups.
Only £34.99 inc VAT.
ORDER NOW
TP-Link 300Mbps Wireless N PCI Adapter (TL-WN851N) @ £17.99 inc VAT
The TL-WN851N Wireless N PCI Adapter complies with IEEE 802.11n, IEEE 802.11g, and IEEE 802.11b standards. Wireless transmission rates can reach up to 300Mbps. The PCI card employs MIMO technology and has two external detachable omni directional antennas providing even better wireless performance, transmission rates, stability and coverage. At the same time, CCA technology automatically avoids channel conflicts using its channel selection feature. This product supports 64/128/152-bit WEP encryptions, as well as WPA/WPA2 and WPA-PSK/WPA2-PSK encryptions and mechanisms in addition to the adapter’s QSS (Quick Secure Setup) feature, allowing users to quickly and easily configure wireless security. This product can also simultaneously operate bandwidth intensive applications such as voice and video. Applications using a lot of bandwidth that are sensitive to interruptions such as voice and video applications are given priority in order to assure quality. It also works well with other 11g and 11n protocol wireless products.
- 300M Wireless transmission rate
- MIMO technology with stronger signal penetration strength, wider wireless coverage, providing better performance and stability
- CCA technology automatically avoids channel conflicts using its channel selection feature
- Compatible with 11g and 11b equipment, Intel Centrino Compatibility tested
Only £17.99 inc VAT.
ORDER NOW
TP-Link 150Mbps Wireless Lite N PCI Express Adapter (TL-WN781N) @ £11.50 inc VAT
TP-LINK TL-WN781ND is designed to provide a complete end-to-end wireless performance from the server or server backbone to the switch infrastructure and down through to the desktop with the PCI Express connector. TL-WN781ND Wireless Lite N PCI Express(x1) Adapter provides a wider compatibility, fitting with any standard PCI Express slot, x1, x4, x8, or x16. Compared with standard PCI network cards, it offers increased bandwidth, reliability and more functionality, allowing you to enjoy a fast and advanced connection, such as downloading, making internet call and video streaming.
Complying with IEEE 802.11n, 802.11g and 802.11b standards, the TL-WN781ND Wireless Lite N PCI Express Adapter can perfectly interoperate with all the 802.11n/b/g devices. With WMM based on the IEEE 802.11e, it provides Quality of service (QoS) and prioritizes the network traffic. Also, WMM Power Save guarantees lower power consumption for environmental work.
TL-WN781ND features Quick Security Setup (QSS) function, which is ideal for creating an efficient and safe connection to prevent outside intrusion, and meanwhile maximize the management resources. With the external and detachable antennas, the TL-WN781ND can fit different operation environment and guarantee the easy installation.
The device comes with an auto-run CD that provides information about completing the internet connection step by step, which is quickly and hassle-free for any users, especially for novice users.
- Up to 150Mbps wireless transmission rate
- Provides PCI Express interface
- Advanced secure connection with WPA/WPA2 encryption
- Bundled utility enables easy management
Only £11.50 inc VAT.
ORDER NOW
TP-Link 200Mbps Powerline Adapter Twin Pack (TL-PA201) @ £44.00 inc VAT
Establishing a powerline network requires at least two PLC adapters for the first time, the TP-LINK Powerline Ethernet Adapter Starter Kit is good for initially setup which including two same adapters -TL-PA201 2.0. It takes advantage of your home´s existing electrical wiring to create or extend a network. With no additional wiring required, users can simply plug the TL-PA201 into existing power sockets and establish networking infrastructure in a flash. With data transfer rates of up to 200Mbps, you can expand your current home power lines network and experience blinding transfer speeds. Now, enjoy HD video streaming, online gaming, VoIP or any other high bandwidth intensive tasks such as multiple downloads available in minutes instead of hours.
Up to 200Mbps, Ideal for High Definition Video Streaming
With advanced HomePlug AV technology, TL-PA201 provides users with stable and high-speed data transfer rates of up to 200Mbps. TL-PA201 features an easy-to-use interface for configuring Quality of Service options, supports multiple streams of HD video as well as popular Voice over IP (VoIP) throughout the home or office.
Twin Pack Design
NO New Wires, Just Plug And Play
No configuration required, just connect your PC to a powerline adapter and plug it into a power outlet and instantly transform your household power grid into a fully functional network, with no need to drill through the walls and climb through the attic or cellar to install network cables. Messy cabling and wireless dead spots are now things of the past.
Green Product with Lower Power Consumption
The TL-PA201, a new-generation Powerline Adapter, consumes less power when compared with existing Powerline Ethernet Adapters. Moreover, when there is no Ethernet link, it will automatically switch from its regular "working" power mode to standby mode that reduces energy waste by over 65%* when compared to adapters without this feature.
Pair Button for Easy Network Security
Simply push the Pair button on the adapters and then you can set up a hassle-free Powerline network within minutes, which features 128-bit AES encryption for network security and data protection.
Only £44.00 inc VAT.
ORDER NOW
TP-Link 3G/3.75G Wireless N Router (TL-MR3420) @ £29.99 inc VAT
3G On-the-Go
TP-LINK's TL-MR3420 3G/3.75G Wireless N Router allows you to quickly set up a 300Mbps wireless network on-the go and share a 3G/3.75G mobile connection. By connecting a UMTS/HSPA/EVDO USB card to the router, a Wi-Fi hotspot is instantly established allowing users to share an Internet connection anywhere 3G/3.75G coverage is available. So whether you're on the train, camping, or at a construction site, you'll have a reliable wireless connection to accommodate your networking needs.
Always Connected
Nothing is more frustrating than losing your Internet connection in the middle of your work. To avoid such interruptions and provide our customers with an always-online connection, TP-LINK is introducing the TL-MR3420, a robust 3G/3.75G wireless N router with true 3G/WAN failover capability.
You can set a primary link, 3G/3.75G or WAN (xDSL/Cable). TL-MR3420 switches to the secondary link when your primary service is interrupted. Once the service is restored, the router will automatically failback to the primary link–keeping your business online with the minimal interruption to users.
- Compatible with UMTS/HSPA/EVDO USB modems, tested in the field
- 3G/WAN failover guarantees an 'always-online' Internet connection
- Wireless N speed up to 300Mbps
- Supports PPPoE, Dynamic IP, Static IP, PPTP, L2TP Cable Internet access
- SST technology dramatically increases link robustness and stability
- CCA technology enhances your signal stablility by automatically avoiding channel conflicts
- Wireless security encryption easily at the push of the QSS button
- WDS wireless bridge provides seamless bridging to expand your wireless network
- IP based bandwidth control allows administrators to determine how much bandwidth is allotted to each PC.
Hardware Specification
Interface
USB 2.0 Port for UMTS/HSPA/EVDO USB Modem
1 10/100Mbps WAN Port, 4 10/100Mbps LAN Ports, support the auto-Negotiation and auto-MDI/MDIX
Antenna
3dBi Detachable Omni Directional Antenna X 2
Power Supply Unit
Only £29.99 inc VAT.
ORDER NOW
For this weekend only the TD-W8950N is being sold at cost while stocks last.
TP-Link Wireless Lite N ADSL2+ Modem Router 150Mbps / 4port 10/100 / Wireless Lite N Access Point - (TD-W8950N) @ £23.49 inc VAT
TP-LINK 150Mbps Wireless ADSL2+ Modem Router TD-W8950ND is a high performance modem router that provides a full rate of ADSL2+ standard with the superb reliability and a cost-effective solution for home and small business. It is a 3-in-1 device that combines the function of a high-speed DSL modem, a 4-Port 10/100Mbps NAT router and a wireless Lite N access point. Using the TD-W8950ND, you can easily create a secure and high-speed wireless network and enjoy more kinds of bandwidth consuming applications like HD video streaming wirelessly which can not be accommodated by 11g products, from anywhere in your entire home or even the yard.
Features
- High speed DSL modem, NAT router and wireless access point in one device provides one-stop networking solution
- Wireless speed up to 150Mbps makes it ideal for bandwidth consuming or interruption sensitive applications like online gaming and even the HD video streaming
- Easy Setup Assistant1 provides quick & hassle free installation
- WPA/WPA2 encryptions provide your network with active defense against security threats
- SPI and NAT firewall protects end-user devices from potential attacks across the Internet
- Easily setup a WPA encryption secured connection at a push of QSS button
- QoS enables smooth IPTV streaming and lag-free online gaming
- Support up to 10 IPSec VPN tunnels simultaneously
- Auto-reconnect keeps you online indefinitely
- Backward compatible with 802.11b/g products
Only £23.49 inc VAT.
ORDER NOW
TP-Link Wireless N 300Mbps Wireless USB Adapter (TL-WN821N) @ £10.56 inc VAT
The TL-WN821N Wireless N USB Adapter complies with IEEE 802.11n, IEEE 802.11g, and IEEE 802.11b standards. Wireless transmission rates can reach up to 300Mbps. The adapter employs MIMO technology and has internal Intelligent Antennas providing even better wireless performance, transmission rates, stability and coverage. At the same time, CCA technology automatically avoids channel conflicts using its channel selection feature. This product supports 64/128-bit WEP encryptions, as well as WPA/WPA2 and WPA-PSK/WPA2-PSK encryptions and mechanisms in addition to the adapter’s QSS (Quick Secure Setup) feature, allowing users to quickly and easily setup wireless security. This product can also simultaneously operate bandwidth intensive applications such as voice, and video. Applications using a lot of bandwidth that are sensitive to interruptions such as voice and video applications are given priority in order to assure quality. It also works well with other 11g and 11n protocol wireless products.
- Supports Sony PSP for online game
Only £10.56 inc VAT.
ORDER NOW
TP-Link 150Mbps Wireless Lite N USB Adapter (TL-WN727N) @ £7.50 inc VAT
TP-LINK TL-WN727N is designed to provide a high-speed and unrivaled wireless performance for your computer. With a faster wireless connection, you can get a better Internet experience, such as downloading, gaming, video streaming and so on.
The TL-WN727N Lite N USB Adapter complies with IEEE 802.11g, and IEEE 802.11b standards. It can perfectly interoperate with all the 802.11n/g/b devices. The TL-WN727N´s auto-sensing capability allows high packet transfer rate of up to 150Mbps for maximum throughput.
Additionally, the TL-WN727N supports QSS function, which can help you create a wireless connection with effortless security setup, to prevent outside intrusion and protect your personal information from being exposed.
Featuring high performance transmission rates, simple installation and adaptability, as well as strong security, the TL-WN727N Lite N USB Adapter is a perfect solution for small office and home needs.
- Simple Configuration and monitoring
- Supports Windows 2000/XP/Vista OS
Only £7.50 inc VAT.
ORDER NOW
TP-Link Extended Range 54M wireless ADSL2 Router (TD-W8901G) @ £19.96 inc VAT
The TP-Link 54M Wireless ADSL2+ Modem Router TD-W8910G is a 3-in-1 device that combines the function of a high-speed DSL modem, wireless G access point, and 4-port Ethernet router. It supports the latest ADSL2/2+ standards to provide higher performance (up to 24Mbps downstream and 3.5Mbps upstream) and longer reach from your Internet Service Provider´ (ISP) Digital Subscriber Line Access Multiplexer (DSLAM).
With the TD-W8910G, you can create a wireless network to connect 802.11g/802.11b devices as well as a wired network to connect up to four 10/100 Ethernet devices.
The TD-W8910G includes a built-in QoS engine that helps prioritize Internet traffic to enable smooth Internet phone calls (VoIP) and lag-free online gaming. To prevent unauthorized wireless access into your network, the TD-W8910G supports the latest encryption including WEP, WPA, and WPA2.
Whether it is for a home or for a small office user, TD-W8910G is the ideal all-in-one broadband and wireless networking solution.
The device comes with a CD with an Easy Setup Assistant that helps you step by step to complete your Internet connection, wireless network settings and security configurations. This feature allows even novice users to setup the router products without sacrificing any key features, just play the AUTO-RUN CD bundled to have your network set up quickly & hassle-free.
- 3-in-1: ADSL2+ modem,4-port Ethernet router and wireless G access point
- Easily share ADSL connection with all office or home computers,wired or wirelessly
- Built-in firewall supporting IP address filtering, MAC address filtering and parental control
- Supports DHCP, Universal Plug-and-Play (UPnP), and includes a user-friendly Setup Wizard which takes you through configuring your network, step by step
- Administer and Upgrade the Router Remotely over the Internet
Only £19.96 inc VAT.
ORDER NOW
TP-Link 300Mbps Wireless N ADSL2+ Modem Router (TD-W8960N) @ £35.24 inc VAT
3-IN-1 DEVICE:
The TP-LINK Wireless N ADSL2+ Modem Router (TD-W8960N) is an All-in-One device that combines the functions of a high speed DSL modem, a 4-Port 10/100Mbps NAT router and a wireless N access point. The TD-W8960N is designed to give you a one-stop solution to acquiring and sharing high speed Internet access over a wired/wireless network.
ACCESS HIGH-SPEED INTERNET:
Supporting the latest ADSL standards to provide higher performance (up to 24Mbps downstream and 3.5Mbps upstream) and longer reach from your Internet Service Provider (ISP) Digital Subscriber Line Access Multiplexer (DSLAM), the TD-W8960N brings with it much higher speed than a dial-up connection without tying up the phone line. This device also supports TR-069, which automatically updates the firmware and other settings when they become available from your ISP.
SHARING INTERNET THROUGH WIRELESS:
Complies with the IEEE 802.11n standard, users can create a wireless network and get up to 15X the speed and 5X the range of conventional 11g products. Now you can share your high-speed DSL Internet connection, photos, music, videos, printers, Network Attached Storage (NAS) and even the bandwidth consuming applications like HD video streaming wirelessly which can not be accommodated by 11g products, from anywhere in your entire home or even the yard ! The TD-W8960N supports QoS to enable smooth VoIP/IPTV streaming and lag-free online gaming.
In addition, this device includes Dual Active Firewalls (SPI and NAT) to help protect your network from potential attacks from across the Internet. To prevent unauthorized wireless access into your network, the device supports the latest encryption including WEP, WPA and WPA2.
QUICK SECURE SETUP:
QSS or Quick Security Setup is a handy feature that allows users to almost instantly setup their security simply by pressing the QSS button on the wireless router or entering the PIN Code in the net card, it automatically establishes a WPA2 secure connection, instantly protecting your network. With just one click of the QSS button, it automatically establishes a WPA2 secure connection for solid security in under a minute.
KEEP DATA SECURE:
Featuring IPSec VPN function, TD-W8960N allows off-site or traveling users to securely access the company´s central network through the Internet. VPN is short for Virtual Private Network, which creats encrypted tunnels through the Internet between the company´s private network and the remote or traveling users off-site. These tunnels are using virtual connections instead of the dedicated, real-world connection such as leased line. Featuring IPSec VPN function, the TP-LINK TD-W8960N is no longer just a wireless ADSL modem router, it can work as a VPN gateway, which supports up to 10 IPSec VPN tunnels simutaneously. As such, users can allow for complete data privacy for the access and exchange of user´s most sensitive data from home to corporate network or between remote branch offices safely.
EASY TO USE:
- ADSL modem, NAT router and wireless N access point in one device provides one-stop networking solution
- Great for on-line gaming, making Internet call or even HD video streaming
- QoS enables smooth VoIP/IPTV streaming and lag-free online gaming
- Supports IPSec VPN tunnels for security connection between the company´s network and your home or branch office
Only £35.24 inc VAT.
ORDER NOW
TP-Link Wireless N DSL 4-port Gigabit Router, 3x3 MIMO, up to 300M with detachable antennas (TL-WR1043ND) @ £39.89 inc VAT
The TP-LINK Wireless N Gigabit Router TL-WR1043ND is a combined wired/wireless network connection device integrated with internet-sharing router and 4-port Gigabit switch. Adopting advanced MIMO™ (Multi Input Multi Output) and SST™ technologies, it provides incredibly high wireless speeds of up to 300Mbps. The TL-WR1043ND also features four Gigabit Ethernet ports for wired connections. This robust guaranteed wired/wireless throughput ensures that you are freer to simultaneously enjoy multiple high-bandwidth consuming and interruption sensitive applications such as streaming HD video, making VoIP calls, sharing large files and playing online games. The TL-WR1043ND is specially equipped with a USB storage port on the back of the router for connecting USB storage devices, for convenient access for everyone on the network.
*Some official firmware of TP-LINK products can be replaced by the third party firmware such as DD-WRT. TP-LINK does not provide technical support and does not guarantee the performance and stability of third party firmware. Damage to the product as a result of using third party firmware will void the product's warranty.
- Gigabit Ethernet ports enabling ultimate transfer speed
- Centrally storing and content sharing by connecting USB storage drives
- SST™ dramatically increases link robustness and stability
- CCA™ improves wireless performance while automatically avoiding channel conflicts
- Wireless N speed up to 300Mbps makes it ideal for bandwidth consuming or interruption sensitive applications like video streaming, online gaming and VoIP
- For home and office use, supports PPPoE, Dynamic IP, and static IP broadband access and various kind of dialing requirements
- Supports UPnP, DDNS, static routing, VPN pass-through, and data forwarding
- Features IP, MAC, URL filtering which flexibly controls online access and time
- Supports SPI firewall and access control management
- Supports QSS (Quick Secure Setup), provides 64/128/152-bit WEP encryption, WPA/WPA2, WPA-PSK/WPA2-PSK authentication
- User interface supports free web software updates
- 3 detachable antennas (reverse SMA connector)
Interface
4 10/100/1000M LAN Ports
1 10/100/1000M WAN Port
1 USB 2.0 Port
Antenna
3dBi Detachable Omni Directional Antenna X 3
Power Supply Unit
Only £39.89 inc VAT.
ORDER NOW
