More prices have been dropped for this weekend only specials.
Arctic Sound P281 Professional headphones @ £14.99 inc VAT
The ARCTIC SOUND P281 is a pair of DJ headset that combines stylish appearance, durability and practicability in an affordable package, made to meet the specific requirements of professional DJs. The ARCTIC SOUND P281 contains a 50mm drive to ensure high-fidelity sound and is constructed with ergonomic features for long hours of usage.
The ARCTIC SOUND P281 has an adjustable and padded headband to provide excellent listening comfort. Leather lining and soft cushion on the earcups provide secure fit and allow the headset to rest comfortably over the ears. Upper headband is made of artificial leather lining to emphasize its stylish appearance, while the underside headband contains netted nylon for sweat absorbing. Its circumaural design wraps firmly over the ears and provides a high level of noise isolation. Hence, this tightly closed and highly insulated structure captures delicate sounds for DJ in noisy ambient settings.
As a DJ headset, the ARCTIC SOUND P281 is designed for music and sound monitoring. The headset can be bent and flexed in many ways. Its 90-degree swivel mechanism on both earcups allows DJs to have the flexibility for single-sided monitoring. The folding design in the ARCTIC SOUND P281 has flexible joints, allowing DJs to fold the headset to half its size for space-saving, travel, and protection. Coiled cable on the headset is heavy and sturdy to prevent excess cable from sitting on the floor or DJ table.
- Superior output power
- Extra-wide frequency response
- Lightweight and comfortable
- Designed for DJs
- Adjustable headband with 90-degree swivel earcups
- Gold-plated standard 3.5mm plug with 6.3mm adapter for wide compatibility
- 2 Years warranty
Was £16.99 Inc. VAT
Only £14.99 inc VAT.
ORDER NOW
Roccat Kave 5.1 Surround Sound Headset @ £61.98 inc VAT
A Desert Eagle isn't worth its fancy name, if you don't know where to aim. Imagine your advantage within the heat of the battle when you exactly hear where your opponents are before you can actually see them. Knowing the position of your enemy is half the frag. Realistic 3D surround sound makes you locate your opponents easily by the noise they generate. The desktop control enables you to adjust to situations quickly with sound and microphone mute buttons and volume control for different channels.
- Real 5.1 Surround sound with speakers aligned at a 12° angle
- Microphone with mute LED fully rotatable and completely removable
- Tip’N’Control desktop remote for central management of all volume functions
- Dual sound-profile with movie and game settings
- Solid aluminium hinges enabling heavy duty use
- Hand-sewn comfortable earcups featuring external noise cancelling
- Adjustable vibration unit for a realistic gaming experience
- Headband with three pads for equal weight distribution
- Easy to carry folding and compact design
Was £64.99 Inc. VAT
Only £61.98 inc VAT.
ORDER NOW
Corsair Gaming Audio Series HS1 USB Gaming Headset @ £67.98 inc VAT
- Massive 50mm drivers for high-quality audio reproduction
- Frequency response tuned to deliver serious gaming punch without sacrificing audio quality for music and movies
- Circumaural, closed-back earcups for superior noise isolation
- Replaceable memory foam earpads with fabric covers for a firm fit without binding or pinching
Was £69.99 Inc. VAT
Only £67.98 inc VAT.
ORDER NOW
Sennheiser PC 360 Gaming Headset @ £129.98 inc VAT
Developed with the top eSport team mTw, the PC 360 is a new flagship for pro gaming. It has an open design that makes sure you keep a cool head – and delivers a natural listening experience so you can stay in touch with your surroundings. Thanks to the ultracomfortable ear cups, pro microphone and quick-access controls, it’s also the only headset you’ll ever
need for music, videos and skyping.
Professional gaming with a cool head - the open design lets air in and delivers a natural listening experience;Sennheiser sound – excellent hi-fi sound and acoustics from your games, music, movies and internet calls;Noise canceling clarity – the microphone reduces ambient noise for crystal-clear conversations;All-in-one headset – when you want to enjoy movies or music, just move the microphone out of your way;Practical microphone mute – automatically mute the microphone by raising the boom.
- Cable length: 3m / 9.8ft
- Connector sockets: 2 x 3.5mm for desktop/laptop
- Weight: 300g
Frequency response:15–28,000Hz
- Sound pressure level: 112dB
- Microphone:
Frequency response: 50–16,000Hz
- Pick-up pattern: Noise canceling
Sensitivity: -38dBV/PA
Was £134.97 Inc. VAT
Only £129.98 inc VAT.
ORDER NOW
Logitech C910 HD 1080p Pro 10 Megapixel Webcam (960-000598) @ £64.98 inc VAT
Individuals using the webcam to communicate with friends and business associates will benefit from its 720p video calls, 1080p HD recording and its ability to capture ten-megapixel stills. Sharing videos and images could not be easier with the Logitech HD Pro Webcam C910 (960-000598) due to its one-click Facebook upload feature, while its life-like audio quality could appeal to some customers. Users can enhance the security of the webcam by using its face recognition login feature, offering peace of mind and protection against unauthorised use. Meanwhile, Carl Zeiss optics combined with RightLight 2 technology and bundled Logitech video effects could make this device an even more appealing purchase for enthusiasts.
- Full HD 1080p video capture (up to 1920 X 1080 pixels) with recommended system*
- HD video calling (1280 x 720 pixels) with recommended system*
- Logitech More HD technology
- Carl Zeiss® optics with autofocus
- Photos: Up to 10 megapixels (software enhanced)
- Built-in mics with Logitech RightSound™ technology
- Hi-Speed USB 2.0 certified (recommended)
- Universal clip fits laptops, LCD or CRT monitors
- 2-year limited hardware warranty
Basic requirements:
- 1 GHz
- 512 MB RAM or more
- 200 MB hard drive space
- Internet connection
- USB 1.1 port (2.0 recommended)
- Windows® XP (SP2 or higher), Windows Vista® or Windows® 7 (32-bit or 64-bit)
For HD 720p video calling and Full HD 1080p video recording:
- 2.4 GHz Intel® Core™2 Duo
- 2 GB RAM
- USB 2.0 port
- 1 Mbps upload speed or higher
- 1280 x 720 screen resolution
Was £69.98 Inc. VAT
Only £64.98 inc VAT.
ORDER NOW
Saitek PZ52P VGA Webcam - Pink @ £2.50 inc VAT
This great value webcam which is fully compatible with laptops, netbooks and desktop PCs is perfect for video messaging applications. Keep in contact with your friends, family and loved ones.
- Easy Capture, click and send
- 640 X 480 resolutions
- Broadcast live video over the web
- Great for video chat, video mail & video conferencing
- Works with MSN, Yahoo, Windows Messenger & more
Was £2.99 Inc. VAT
Only £2.50 inc VAT.
ORDER NOW
OcUK Value 300Mbps Wireless-N USB Adapter @ £8.50 inc VAT
The GN-621U is complied with wireless 802.11b/g/n standards with latest 11n MIMO technology to increase the wireless speed up to 6 times faster and extends the range 4 times further. The GN-621U also reduces "dead spots" within the wireless coverage. The transmission data rate when connecting with wireless 802.11n devices is up to 300Mbps, which makes signal travel farther and maintain wireless connections much reliable than traditional wireless 802.11b/g network.
Wi-Fi Protected Setup (WPS) is a standard for easy and secure establishment of a wireless network. This wireless USB adapter supports software WPS configuration. When both ends of the wireless devices supporting WPS, it will automatically configure the wireless network with robust WPA data encryption and authentication.
- Complies with wireless IEEE802.11b/g and IEEE802.11n standards
- Increases wireless coverage 4 times further
- Includes multi-language setup wizard
- Supports 64/128-bit WEP, WPA , WPA2 encryption and software WPS button
- Interface: USB 1.0/2.0 Type A One LED for Link/Activity 2 x Internal Printed Antennas
- Data Rate
- 11b: 1/2/5.5/11Mbps
- 11g: 6/9/12/24/36/48/54Mbps
- 11n (20MHz): MCS0-7 (up to 72Mbps)
- 11n (40MHz): MCS0-7 (up to 150Mbps)
- Security & Support OS:
- Supports 64/128-bits WEP, WPA, WPA2 for Security
- Support Windows 98SE/ME/2000/XP/Vista
- Standard & Frequency Band: Complies with IEEE802.11b/g and IEEE802.11n Standards
- 2.4 GHz
- Functions: Supports WMM (QoS)
- Supports Software WPS configuration
- Dimensions: 9 x 19.2 x 56 mm
- Certifications: CE & FCC
(please note product may vary from picture)
Was £8.99 Inc. VAT
Only £8.50 inc VAT.
ORDER NOW
Belkin F5D8633UK4A 300Mbps Wireless N ADSL2+ Modem/Router @ £23.98 inc VAT
Connect your wired and wireless desktop computer and notebooks to your Belkin N Wireless Modem/Router to share your broadband internet access. Now you can quickly exchange documents, share resources, and distribute large video and music files throughout your network at a link rate of up to 300Mbps which can save you time.
Belkin's advanced security protects both your wireless and wired computers from hackers and intruders, providing you with the peace of mind you require for your security of your data and personal information. You can add up to 16 computers to your wireless network with additional notebook and desktop adapters.
- Data transfer rate of up to 300 Mbps
- Plug and Play Setup making it easy to setup your home network
- Ports: ADSL Phone Line - 10/100 LAN Port - 4
- Security Wi-Fi Security modes: WPA, WPA2-Personal, 64-bit/128-bit encryption and multiple SSID to ensure you're protected against viruses and hackers
- Backwards compatable with Wireless A/B/G/N receivers
- VPN Support: Allows you to access your network from any computer in the world.
Was £29.99 Inc. VAT
Only £23.98 inc VAT.
ORDER NOW
Seagate Freeagent Goflex TV 1080p HD Media Player @ £59.98 inc VAT
Enjoy all of your movies, music and photos on your TV, in full 1080p HD with vibrant surround sound. The GoFlex TV HD media player makes it easy to access, view and play your digital media files on your home entertainment system. And because it works with just about every format available, you can enjoy all of your entertainment on your TV or in your home theater - from Flip videos to photos to DVDs - regardless of resolution.
- Plays MKV File format
- Plays your content on your TV directly from your GoFlex ultra-portable drive, or accesses your content from your digital camera, flash drive or other external drives (either Windows® or Mac®) through the additional USB port
- Hooks up to your TV in seconds via a digital HDMI® cable
Connects to your PC or Mac computer, home network and the Internet via Ethernet or wirelessly with the optional Wi–Fi Adapter
- Lets you watch streaming media direct from the Internet, your computer and your USB devices
- Displays all the content that is included with your DVDs, including menus, commentator tracks and subtitles
- Makes navigating and accessing your digital media files easy with the included remote control and intuitive on–screen menus
- Creates exciting slideshows with your own music track for enjoying memories with friends and family
Fits seamlessly within your entertainment centre
Flexible options for accessing your content
- Access content directly from your GoFlex or GoFlex Pro ultra-portable drive through the integrated GoFlex ultra-portable drive slot, or any USB external drive through the USB ports
- Access content from your network through a GoFlex Net media sharing device, in-home media server, or network-connected PC or Mac
Access the Internet services you use every day
Now you can enjoy some of the most popular Internet sites right on your TV, including:
- YouTube
- Paramount
- vTuner
- Mediafly
- Picasa
- Flickr
- Video Feeds (RSS)
- Text Feeds (RSS)
- Finance Widget
- Weather Widget
What's included?
- GoFlex TV HD Media Player
- AV, component and Ethernet cables
- Power supply
- Remote control
- 1-year limited warranty
Was £65.97 Inc. VAT
Only £59.98 inc VAT.
ORDER NOW
Logitech C510 HD 720p 8 Megapixel Webcam (960-000594) @ £29.98 inc VAT
With HD 720p video calling and one-click HD upload to Facebook, now you can share your HD world—anywhere, anytime.
- Video capture: Up to 1280 x 720 pixels
- Photos: Up to 8 megapixels (software enhanced)
- Built-in mic with Logitech RightSound™ technology
Basic requirements:
- 1 GHz
For HD 720p video calling and recording:
- 2 GB RAM
- USB 2.0 port
Was £31.98 Inc. VAT
Only £29.98 inc VAT.
ORDER NOW
- Designed for DJs
- 2 Years warranty
Was £16.99 Inc. VAT
ORDER NOW
Was £64.99 Inc. VAT
ORDER NOW
Was £69.99 Inc. VAT
ORDER NOW
- Weight: 300g
- Microphone:
ORDER NOW
Basic requirements:
- 1 GHz
- 2 GB RAM
- USB 2.0 port
Was £69.98 Inc. VAT
ORDER NOW
Was £2.99 Inc. VAT
Only £2.50 inc VAT.
ORDER NOW
- Data Rate
- 2.4 GHz
Was £8.99 Inc. VAT
Only £8.50 inc VAT.
ORDER NOW
Was £29.99 Inc. VAT
ORDER NOW
- YouTube
- Paramount
- vTuner
- Mediafly
- Picasa
- Flickr
- Video Feeds (RSS)
- Text Feeds (RSS)
- Finance Widget
- Weather Widget
What's included?
- Power supply
- Remote control
Was £65.97 Inc. VAT
ORDER NOW
Basic requirements:
- 1 GHz
- 2 GB RAM
- USB 2.0 port
Was £31.98 Inc. VAT
ORDER NOW
