** ROUND 7 OF WEEKEND DEALS - CASES **
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Zalman Z9 Plus Tower Case with Fan Controller - Black @ £42.98 inc VAT
The latest offering from Zalman is the Z9 Plus which offers amazing value and great features. This chassis is a must for any new build. Regulating your interior temperature has never been so simple: as the Z9 Plus includes a built in fan controller and LED temperature sensor allowing you to fine tune your cooling. The Z9 comes equipped with a well designed side window to showcase all your components and allow further cooling with its semi-mesh design.
- Motherboard tray cut out for easy CPU backplate removal
- Dimensions: 207 x 464 x 504mm (W x H x D)
- 3 x 5.25" Drive Bays
- 6 x 3.5" Drive Bays
- 1 x 2.5" Drive Bay
- Expansion Slots: 7
- Space for 290mm Graphics Cards
- Front I/O Ports: USB2.0 x 4 / 2 x Audio / Fan Controller / Temperature display
- Front Cooling: 120mm /140mm fan x 1 (120mm Blue LED fan x 1 standard)
- Top Cooling: 120mm /140mm fan x 2 (120mm Blue LED fan x 1 standard)
- Bottom Cooling: 120mm /140mm fan x 1 (optional)
- Rear Cooling: 120mm fan x 1 (included)
- Side Cooling: 120mm fan x 2 (120mm Blue LED fan x 1 included)
Was £44.99 Inc. VAT
Only £42.98 inc VAT.
ORDER NOW
OCUK EZCool NA-705 Case - Black (500w PSU) @ £21.98 inc VAT
The NA-705 is an entry level range which meets the latest thermal requirements.
- Front Panel-Light up Blue highlight LED
- CPU support: Dual Core
- Driverbay: 3*5.25 external
- 1 x 3.5 external
- 4 x 3.5 internal
- Chassis: 1 x80mm rear fan Space: 1 x 80mm front fan space
- Fan Duct
- Compatible M/B : MATX
- Riveted 0.6mm Japanese SECC metal frame in metallic silver PSU- 500w
- Dimensions: 180mm 445mm 410mm (W x D x H)
Was £24.99 Inc. VAT
Only £21.98 inc VAT.
ORDER NOW
Fractal Design Define R3 Midi Tower Case - Black Pearl @ £79.99 inc VAT
The Define R3 case is reaching new heights in combining stylish, contemporary design with maximum functionality and noise absorbing features. The minimalistic, yet stunning front panel design, fitted with noise absorbing material on the inside, creates an aura of exclusivity. The patent pending feature ModuVent™, in which you can choose whether to have side and top panels open or not, makes the case appealing for users seeking optimal silence, as well as the performance hungry ones. The sleek black interior is matched with pre-fitted, dense noise absorbing material on the side panels, efficiently absorbing noise and vibrations. You can fit an astonishing total of eight(!) hard drives into this case, using the user friendly HDD-trays. All painted in a nice white color and using black silicone mounts. PSU is mounted in the bottom of the case, with a convenient pull-out filter beneath it. Are you one of those users always ending up with a case full of tangled cables? No more. The Define R3 offers a convenient and good looking way of hiding them away. The motherboard has rubber covered holes in which you can easily route the cables behind the motherboard.
- Stunning front panel design
- Patent pending ModuVent™ design, allowing the user to either have optimal silence or optimal airflow
- Pre-fitted with dense, noise absorbing material
- 8 white painted HDD-trays, with silicone mounting
- A total of 7 fan slots (2x120mm in front, 2x 120/140mm in top, 1x120mm in back, 1x 120/140mm in side panel, 1x 120/140mm in bottom)
- 2x 120mm Fractal Design 120mm fans included
- Fan controller for 3 fans included
- Easily removable front fan filters with clip-on holders for 120mm fans
- Supports graphic card lengths up to circa 290mm and CPU coolers with height of maximum circa 165mm
- 1 rear Fractal Design 120mm @ 1350rpm included
- 1 front Fractal Design 120mm @ 1350rpm included
- 1 front 120mm fan (optional)
- 1 bottom 120mm/140mm fan (optional)
- 1 side panel 120mm/140mm fan (optional)
- 2 top 120mm/140mm fan (optional)
- Case size (WxHxD): 207.4 x 440 x 521.2mm
Improvements from R2
- Improved air flow with updated fans
- Improved noise absorbing material
- Bigger hole in M/B plate for mounting of CPU Coolers
- Improved cable routing possibilities
- Reset button, located behind the front panel door
- Many small quality improvements, including improved scratch resistant coating
Was £84.99 Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
Cooler Master CM-690 II Lite Dominator Case - Black @ £55.99 inc VAT
The CM 690 II Lite raises the bar again, but with value for money, with practical improvements over the top-selling CM 690. The spacious mid-tower will keep enthusiasts happy with room for up to 3 vga cards, high-end CPU coolers, top or bottom mount water cooling radiator and 1.8"/2.5" drive adapter. It also features much improved airflow with oversized mesh and enough space for up to 10 fans. Maintenance will be a breeze with the tool-free drive bays, new cable management and CPU cooler retention hole.
- Dimensions: 214 x 511 x 528mm
- Motherboard Compatiblity: ATX, Micro-ATX, Mini-ITX
- Room for 120 x 240mm Radiator inside the top and bottom
- Cable management and CPU retaining holes for easy maintainence
- Support Tri-GFXs
- 4 x 5.25" Drive Bays
- 7 x 3.5" Drive Bays
- I/O Panel: USB2.0, 1 x eSATA, 2 x Audio
- Front Cooling: 1x 120 mm (17 dBA)
- Rear Cooling: 1x 120 mm (17 dBA)
- Top Cooling: 2 x 140 / 120 mm (optional)
- Bottom Cooling: 2 x 120 mm (optional)
- HDD Cage cooling: 1x 120 mm (optional)
Was £59.99 Inc. VAT
Only £55.99 inc VAT.
ORDER NOW
Antec 300 Three Hundred Ultimate Gaming Case - Black @ £47.99 inc VAT
Impressively spacious and unbeatably reliable, the Antec Three Hundred is an unbeatable enclosure. Despite its eminently portable frame, the Three Hundred has enough room for all the latest flag-ship graphics cards, as well as six hard drives and a standard ATX motherboard. A cable management compartment keeps your system organized and the airflow unobstructed. A 120mm rear fan and 140mm top fan ensure that the case runs cool even when playing the most demanding games, while the sleek black finish gives it an extra stylish edge.
- External 3 x 5.25"
- Internal 6 x 3.5" for HDD
- 1 rear 120 x 25 mm TriCool™ Fan with 3-speed switch control.
- 1 top special 140 x 25 mm TriCool™ Fan with 3-speed switch control
- 2 front (optional) 120 mm fans to cool the hard drives
- 1 side (Optional) 120 x 25 mm Fan to cool graphic cards
- Washable air filters reduces dust build up in your system, which helps keep your system cooler
- Perforated front bezel for maximum air intake
- 7 expansion slots
- Top mounted I/O ports for easy access
- 2 x USB 2.0
- Dimensions: 458mm (H) x 465mm (D) x 205mm (W)
- HDA & AC’97 Audio In and Out
Was £50.99 Inc. VAT
Only £47.99 inc VAT.
ORDER NOW
i can the zalman and coolermaster lite are going to be recommended a lot over the weekend. however, the fractal im not so sure about, and the antec certainly wont get recommended until its a lot cheaper than the superior antec 100
