Round 7 is here! Bring the noise with these Top Quality sound products. Give yourself the Gaming Advantage or even to relax watching films or music the way the producers intended it to sound.
Asus Xonar Xense Sound Card + Sennheiser PC 350 Xense Edition Headset @ £174.99 inc VAT
The new Asus Xonar Xense One and Sennheiser PC 350 Xense Edition package is the result of cooperation between Asus and premier personal audio maker, Sennheiser. Xonar Xense is a perfectly matched combination of cutting edge audio card and superior quality headphones that reinvents immersive sound for serious gamers. The gaming audio set creates unbeatable sonic experiences in PC gaming that are sure to be appreciated by hardcore gamers keen on competitive online play.
- Powerful headphone amplifier and matched high-impedance driver secure FPS-optimized sound positioning and dynamics
- No footsteps missed in front of the 118dB SNR sound clarity brought by EMI shield and studio-standard 6.3mm audio jack
- Stylish full-stainless steel design matches the earcup cover of Sennheiser headset
- Pro gamers’ long-hour usage catered by excellent headset ergonomics
- New Gain Level perfectly tuned up for the PC 350 headset
Only £174.99 inc VAT.
ORDER NOW
Logitech G35 7.1 Surround Sound Headset (981-000117) @ £75.19 inc VAT
The Logitech G35 headset. Game-changing immersion with 7.1 surround sound powered by Dolby technology for a detailed soundfield - hear your enemies before they see you. Featuring three swappable headband pads so you can choose the best fit, for long-lasting comfort; three customizable G keys for one-touch command over music, voice morphing, and more; on-ear audio controls for quick access to volume, microphone mute, and surround sound adjustments; and an adjustable, noise-canceling microphone that focuses on your voice and reduces background noise.
- 7.1 surround sound powered by Dolby technology delivers a detailed soundfield - hear your enemies before they see you.
- Three swappable headband pads let you choose the best fit, for long-lasting comfort.
- Three customizable G keys give you one-touch command over music, voice morphing, and more.
- On-ear audio controls provide quick access to volume, microphone mute, and surround sound adjustments.
- Adjustable, noise-canceling microphone focuses on your voice and reduces background noise.
Only £75.19 inc VAT.
ORDER NOW
SpeedLink Medusa NX 5.1 Gaming Surround Sound Headset (SL-8793-SBK) @ £44.64 inc VAT
Find yourself right at the centre of the action with this 5.1 surround headset: hear a door closing behind you to your left or listen to the footsteps of your opponent who’s in front of you. Plug the Medusa into the 5.1 soundcard on your PC or using the phono adapter and mains adapter, into your DVD player.
- Real 5.1 gaming surround sound
- Real all-rounder - can be used on all sound sources
- Brilliant voice transmission
- Highest level of comfort
- Adjust sound channels individually
- Collapsible headset including carry case
- 3.8m cable
Only £44.64 inc VAT.
ORDER NOW
Roccat Kave 5.1 Surround Sound Headset @ £69.99 inc VAT
A Desert Eagle isn't worth its fancy name, if you don't know where to aim. Imagine your advantage within the heat of the battle when you exactly hear where your opponents are before you can actually see them. Knowing the position of your enemy is half the frag. Realistic 3D surround sound makes you locate your opponents easily by the noise they generate. The desktop control enables you to adjust to situations quickly with sound and microphone mute buttons and volume control for different channels.
- Real 5.1 Surround sound with speakers aligned at a 12° angle
- Microphone with mute LED fully rotatable and completely removable
- Tip’N’Control desktop remote for central management of all volume functions
- Dual sound-profile with movie and game settings
- Solid aluminium hinges enabling heavy duty use
- Hand-sewn comfortable earcups featuring external noise cancelling
- Adjustable vibration unit for a realistic gaming experience
- Headband with three pads for equal weight distribution
- Easy to carry folding and compact design
Only £69.99 inc VAT.
ORDER NOW
Asus CineVibe Rumble Feedback USB Gaming Headset @ £39.99 inc VAT
Immerse yourself. Feel every glancing blow and get yourself in the game like never before. The ASUS CineVibe is here and brings tactile bass vibration to a level never found before to give you that competitive edge. With ASUS audio engineering at the heart of the CineVibe, there really has never been a headset like this. The CineVibe is a plug & play USB headset that delivers the full audio package without the need for pesky driver installation. Comfort and precision are the most important aspects of any gaming headset and the gamers spirit is captured here - Shoot first and ask questions later because with CineVibe, there are no points for second place.
- USB Plug & Play - No drivers needed!
- Tactile Vibrations - Get yourself in the game!
- Volume, Microphone and Vibration control - Adjust volume, microphone mute and vibration on or off at the flick of a switch!
- Fold Flat Design - Easy to transport to LANs!
- Directional Noise Cancelling Microphone - Clear communication is the key to victory!
Only £39.99 inc VAT.
ORDER NOW
Creative Fatal1ty HS-1000 Gaming USB Headset (51EF0210AA001) @ £52.99 inc VAT
The Fatal1ty USB Gaming Headset HS-1000 delivers the audio you need for a winning performance. Its powerful X-Fi technology brings you 3D positional surround sound so effective in combat that it’s endorsed by ‘Fatal1ty’, the world-famous gamer. With EAX support, the HS-1000 also makes hundreds of compatible games sound more realistic. Its light, flexible headband and soft earpads ensure ultimate comfort during long gaming sessions, aided by the fast-acting in-line volume control. USB connectivity makes for easy installation, while the detachable noise-cancelling microphone ensures optimum performance in intensive team competition. The HS-1000 is your best solution for ‘pro’ quality gaming.
- X-Fi technology for EAX gaming effects and accurate 3D positional surround sound. - Hear your - enemies before they reach you!
- USB connectivity for easy installation.
- Creative ALchemy for 3D positional surround sound under Windows Vista.
- Designed for comfort. Cushioned earpads and light, flexible headband reduce listening
- fatigue during intensive gaming.
- Detachable noise-cancelling microphone for clear, precise speech delivery. Your
- commands will always get through!
- Developed with ‘Fatal1ty’ – your assurance of ‘pro’ quality.
Only £52.99 inc VAT.
ORDER NOW
Corsair Gaming Audio Series HS1 USB Gaming Headset @ £76.99 inc VAT
The Gaming Audio Series HS1 USB Gaming Headset is designed for gamers who are serious about audio. Massive 50mm drivers deliver serious gaming punch, without sacrificing the sparkling sound quality you need to enjoy music and movies. Dolby Headphone surround sound gives you a competitive edge, and the noise-cancelling microphone ensures that your teammates and opponents hear you loud and clear. Extra-large earcups and fabric covered memory foam earpads provide a firm fit and excellent noise isolation without binding or pinching, so you’ll keep your cool and keep your head in the game for hours of playtime. The extra-large inline volume and microphone controller is easy to grab when things get fast, and the HS1 is designed and crafted with high-quality materials for years of use.
- Massive 50mm drivers for high-quality audio reproduction
- Frequency response tuned to deliver serious gaming punch without sacrificing audio quality for music and movies
- Circumaural, closed-back earcups for superior noise isolation
- Replaceable memory foam earpads with fabric covers for a firm fit without binding or pinching
Only £76.99 inc VAT.
ORDER NOW
Creative Sound Blaster World of Warcraft Wireless Headset (70GH010000002) @ £148.99 inc VAT
Hear the world of Azeroth like never before!
Experience the sounds of Azeroth and beyond like never before with the Sound Blaster® World of Warcraft® Wireless Headset. Designed specifically for World of Warcraft gamers, the headset features cutting-edge uncompressed wireless audio technology and THX® TruStudio PC, offering you a truly unforgettable gaming experience.
Communicate with your party or raid clearly. The Sound Blaster World of Warcraft Wireless Headset features a professional grade microphone, ensuring everyone can hear your shout of "Heal Me! Heal Me!" in all of its resonant glory. You can even declare your staunch allegiance with the interchangeable headset lenses bearing the marks of your chosen faction and 16 million programmable color illumination options. Get ready to be blown away by the amazing realism from unrivaled headphone surround and gaming sound enhancement technologies.
Advanced uncompressed wireless connection
Immerse yourself in the uncompressed 2.4GHz wireless technology. Powerful audio from Sound Blaster, without the wires of course.
THX TruStudio PC technologies
THX TruStudio PC sound technologies create unprecedented levels of audio realism and includes stunning surround effects, producing virtual speakers around, above, and below you.
Interchangeable headset lense
For the Horde! Glory to the Alliance! Show your allegiance and customize with interchangeable headset lenses. Additional lenses coming soon!
Built-in rechargeable battery
The gnomes have been hard at work. No additional batteries are required and the headset is easily recharged even while in use.
Built-in headset controls
Control your audio even while AFK. Instantly access volume, mute and connection controls directly on the headset.
Oversized padded earcups
Settle in for that epic raid. The headset comes with oversized ear cups with soft leatherette padding, for amazing comfort even during those marathon instance clearing sessions.
VoiceFX technology
Roleplay or have some laughs on your next raid by morphing your voice into different World of Warcraft characters and creatures with VoiceFX technology.
Detachable microphone
Be sure to always get the message across. The detachable noise-canceling microphone gives you clear, precise speech delivery, ensuring your fellow players will hear every word.
World of Warcraft Audio Control Panel
Configure settings easily with custom software that enables you to personalize the illumination of your headset as well as customize your audio experience.
- Driver Units: 40mm Neodymium Magnet
- Frequency Response: 20Hz ~ 20kHz
- Impedance: 32 ohms
- SPL (1kHz): 112dB
- Microphone
- Microphone Type: Noise-Canceling Condenser
- Frequency Response: 100Hz ~ 7kHz
- Impedance: 2.2kohms
- Sensitivity@ 1kHz: -48 dBV/Pa (Uni-directional)
- USB Wireless Transmitter
- Uncompressed 2.4GHz wireless technology
- Re-chargeable lithium polymer battery
- Continuous gaming playback per charge: Up to 9 hours
- Charging Duration: 4 hours
- (Charging via mini-USB jack with bundle cable)
Only £148.99 inc VAT.
ORDER NOW
Logitech Z520 2.0 Speaker System (980-000338) @ £56.39 inc VAT
The Logitech Speaker System Z520. Bring your music to life - at your desk and around the house. Its 360-degree sound helps project audio evenly in all directions, so you get a great listening experience throughout the room. Amplified two-way design reproduces your music, videos and games with natural sound. With 26 watts (RMS) of power, your system is loud enough for a party and detailed enough for subtle tones. Plug your iPod into the auxiliary jack without unplugging the speakers. You’ll get a full range of sound in a stylish package that’s easy to set up, even with your notebook computer, with this two-speaker stand-alone system.
- Its 360-degree sound helps project audio evenly in all directions, so you get a great listening experience throughout the room.
- Amplified two-way design realistically reproduces sound for clear, natural acoustics.
- With 26 watts (RMS) of power, it’s loud enough for a party. And detailed enough for subtle tones.
- Auxiliary input lets you quickly plug in your iPod without having to unplug the speakers from your computer.
- Simple two-speaker standalone system offers a full range of sound in a stylish package that’s easy to set up, especially with notebook computers.
Only £56.39 inc VAT.
ORDER NOW
Logitech Z-5500 THX Certified 5.1 Speaker System (970115-0120) @ £244.99 inc VAT
Many call the Z-5500 Digital speakers the best multimedia system ever. 505-watt RMS and a deep note 25.4 cm (10") subwoofer deliver thundering power, THX-certified, high fidelity, theatre-quality sound. You can simultaneously connect up to 6 audio sources (PCs, video game consoles and DVD/CD/portable music players). Innovative satellite design with removable cloth grilles and rotating pedestals allow desk placement or wall-mounting, so you can transform any room into a home theatre.
- 505w RMS, THX-certified, integrated hardware decoding for true 5.1 digital sound
- Built-in hardware decoding for Dolby Digital & DTS - the only way to get true 5.1 digital sound from PlayStation 2, Xbox, and most DVD players
- 25.4 cm (10”) high-excursion subwoofer driver with flared bass port pounds out powerful distortion-free bass
- Support for 96 kHz / 24 bit digital audio streams for studio-quality sound
- Revolutionary driver technology: polished aluminium phase plug satellites combine two drivers into one: the clarity of a tweeter with the richness and fullness of a separate mid-range
- Dolby Pro Logic II creates realistic 5.1 surround sound from stereo music, movies & games
- Connect to multiple sources: simultaneously connect 6 audio sources including PCs, video game consoles, and DVD, CD & portable music players
- 6 channel direct input can be used as 3 separate stereo inputs
- Digital equalisation actively adjusts frequency response in real time for the cleanest, most accurate sound reproduction
- Innovative satellite design: Cloth grilles are removable for a pro-audio look. Pedestals rotate for easy wall mounting or desk placement. Centre channel can be mounted on wall, above or below monitor
- Wireless remote control: great for use with home theatres and video game consoles
Only £244.99 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
- 3.8m cable
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
VoiceFX technology
- SPL (1kHz): 112dB
- Microphone
ORDER NOW
ORDER NOW
ORDER NOW
