** ROUND 8 OF WEEKEND DEALS - CRAZY MEMORY PRICES! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Some truly stunning prices on memory, so be sure to check them out:-
Corsair XMS3 6GB (3x2GB) DDR3 PC3-16000C9 2000MHz Triple Channel Kit (CMX6GX3M3B2000C9) @ £53.99 inc VAT
Corsair’s mainstream memory solution for the Intel Core i7 triple channel memory processors and platform. The XMS3 family is Corsair’s mainstream line of performance DDR3 memory. These modules allow users to experience outstanding memory performance and stability. Available in Corsair’s new XMS heat spreaders, each module is built using carefully selected RAMs.
- Three matched 2GB modules for use in high performance Intel Core i7 Triple Channel systems
- Outrageously fast 2000MHz performance using 6GB of memory
- Ultra-low 9-10-9-27 latency
- Density: 6GB (3x2GB Module)
- Speed: 2000MHz
- Timing: 9-10-9-27
- Pin Voltage: 1.65V
Was [£59.99] Inc. VAT
Only £53.99 inc VAT.
ORDER NOW
Kingston HyperX Genesis 24GB (6x4GB) DDR3 PC3-12800C9 1600MHz Triple Channel (KHX1600C9D3K6/24GX) @ £149.99 inc VAT
HyperX DDR3 memory; the latest generation of DDR memory technology. Like all Kingston HyperX products, DDR3 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. DDR3 memory offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR2. HyperX DDR3 modules are available in single, dual and triple-channel memory kits.
Features:-
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL X58
CAS Latency: 9-9-9-27 2N
Capacity: 6GB (4GBx6)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.60-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Warranty: Lifetime
Was [£179.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) @ £49.99 inc VAT
Kingston's KHX1600C9D3X2K2/8GX is a kit of two 512M x 64-bit 4GB DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 8GB. Each module kit has been tested to run at DDR3-1600MHz at a low latency timing of 9-9-9-27 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.
Model Name: KHX1600C9D3X2K2/8GX
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67
Capacity: 8GB (4GBx2)
Test Voltage: 1.50-1.65V
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Black PCB
Warranty: Lifetime
Only £49.99 inc VAT.
ORDER NOW
OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Dual Channel Kit (OCZ3G1333LV4GK) @ £22.99 inc VAT
OCZ low-voltage DDR3 kits are designed specifically for the upcoming Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of low power requirements at 1333MHz.
Developed for cost-conscious enthusiasts and gamers, these new OCZ modules were engineered with the same affordability and performance standards as the new Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and OCZ memory are the premium option for the midrange desktops.
OCZ DDR3 PC3-10666 Gold Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1333MHz DDR3
- CL 9-9-9-20 (CAS-TRCD-TRP-TRAS)
- Gold Z3 XTC Heatspreader**
- Lifetime Warranty
- 1.55-1.65 Volts
- 240 Pin DIMM
Was [£27.99] Inc. VAT
Only £22.99 inc VAT.
ORDER NOW
Corsair Value 2GB (1x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Single Channel Module (VS2GB1333D3) @ £11.99 inc VAT
Corsair low-voltage DDR3 modules are designed specifically for the upcoming Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for single & dual channel mode, these ultra-compatible 2GB modules ensure optimal performance with an ideal combination of low power requirements at 1333MHz.
Developed for cost-conscious enthusiasts and gamers, these new Corsair modules were engineered with the same affordability and performance standards as the new Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, Corsair low-voltage kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and Corsair memory are the premium option for the midrange desktops.
Corsair DDR3 PC3-10666 Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance. Furthermore, each Corsair memory module is backed by the industry-leading Corsair Lifetime Warranty and technical support for unparalleled peace of mind.
- 1333MHz DDR3
- Lifetime Warranty
- 1.50 Volts
- 240 Pin DIMM
- Sandybridge compatible
Was [£14.99] Inc. VAT
Only £11.99 inc VAT.
ORDER NOW
Kingston 8gb looks bargainlicious to me .... almost tempted to stick them in a rig that really doesn't need it just for the hell of it.:D
