*****ROUND 8 OF WEEKEND DEALS - MEMORY*****
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Right guys, lots of new memory lines in stock and lots of great deals, so check these out:-
OCZ Reaper 6GB (3x2GB) DDR3 16000C9 2000MHz Triple Channel Kit (OCZ3RPR2000LV6GK) @ £135.00 inc VAT
The OCZ Reaper HPC PC3-16000 triple-channel memory kits are designed specifically for the Intel® Core™ i7 processor / Intel® X58 Express Chipset, the ideal memory kit for enthusiasts demanding the most from their performance systems. Optimized for the Core i7’s triple channel mode, these new 6GB kits ensure optimal performance via an ideal combination of low voltage requirements, blazing speed, and latency.
The Reaper HPC Series makes use of an innovative cooling solution to more effectively dissipate heat produced by high-speed memory, and offers superior cooling technology to ensure superior stability and performance over the entire life of the memory. The thermo-conductive copper heat pipe conduit is ideal for overclocking where every degree matters, ensuring that your cutting-edge investment will maintain its integrity throughout the toughest gaming missions, overclocking, or intense program applications.
Developed for enthusiasts who aren't afraid to overclock, the low voltage Reaper Triple Channel solutions are the choice counterparts for leading-edge performance that won’t inhibit the functionality of Core i7 CPUs. In addition, modules are tested in matched triplets ensuring superior compatibility.
OCZ’s Triple Channel kits are 100% hand-tested for quality assurance and compatibility and feature propriety heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory module is backed by the industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- CL 9-9-9-30 (CAS-TRCD-TRP-TRAS)
- Reaper HPC Heatspreader
- Lifetime Warranty
- 1.65 Volts
Was [£149.99] Inc. VAT
Only £135.00 inc VAT.
ORDER NOW
Corsair Dominator 6GB (3x2GB) DDR3 12800C8 1600MHz Triple Channel Kit (CMP6GX3M3A1600C8) @ £117.49 inc VAT
The DOMINATOR is the ultimate performance memory solution. Limited to only extremely high memory speeds, the Corsair DOMINATOR only uses highly screened IC’s to guarantee performance and over-clockability. Using ultra efficient Dual-path Heat Xchange (DHX) cooling technology. With removable heat sinks, the DOMINATOR modules can even be outfitted with additional upcoming accessories with enhanced features.
- Three matched 2GB modules for use in high performance Intel Core i7 Triple Channel systems
- Outrageously fast 1600MHz performance
- Ultra-low 8-8-8-24 latency
- Intel XMP (Extreme Memory Profile) Support
- Includes new connector for future upgrades and accessories
- Limited Lifetime Warranty
Was [£122.49] Inc. VAT
Only £117.49 inc VAT.
ORDER NOW
OCZ Gold 12GB (3x4GB) DDR3 PC3-12800C8 1600MHz Triple Channel Kit (OCZ3G1600LV12GK) @ £329.99 inc VAT
Home CategoriesDesktop MemoryDDR3ValueGold SeriesOCZ DDR3 PC3-12800 12GB Gold Low-Voltage Triple ChannelOCZ DDR3 PC3-12800 12GB Gold Low-Voltage Triple Channel click for high resolution image
Description Specifications OCZ DDR3 PC3-12800 / 1600MHz / 4GB Modules / Gold Edition / 12GB Triple Channel / Low-Voltage
Addressing the never ending need for greater amounts of system memory, OCZ’s newest Gold Series 12GB Triple Channel kits support the latest memory-hungry applications and games, offering superior performance gains and maximum multi-tasking productivity. Ideal for workstations with 64-bit operating systems, the OCZ 12GB solutions allow users to take advantage of high density memory configurations when working with intensive design and multimedia applications.
The Gold Series 12GB kit is designed specifically for the Intel® Core™ i7 processor / Intel® X58 Express Chipset. Optimized for the Core i7’s triple channel mode, these new 12GB kits ensure optimal performance via an ideal combination of low voltage requirements, speed, and latency.
OCZ Triple Channel solutions are the choice counterparts for leading-edge performance that won’t inhibit the functionality of Core i7 CPUs. In addition, modules are tested in matched triplets ensuring superior compatibility. All Gold Series kits are 100% hand-tested and backed by the OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
Features:-
- 1600MHz DDR3
- CL 8-8-8-24 (CAS-TRCD-TRP-TRAS)
- Unbuffered
- Gold Layered Z3 XTC Heatspreader
- Optimized for X58 Chipsets / Core i7 processors
- 1.65 Volts
- 240 Pin DIMM
- Lifetime Warranty
Only £329.99 inc VAT.
ORDER NOW
OCZ Platinum 12GB (3x4GB) DDR3 PC3-12800C7 1600MHz Triple Channel Kit (OCZ3P1600LV12GK) @ £349.99 inc VAT
Addressing the never ending need for greater amounts of system memory, OCZ’s newest Platinum Series 12GB Triple Channel kits support the latest memory-hungry applications and games, offering superior performance gains and maximum multi-tasking productivity. Ideal for workstations with 64-bit operating systems, the OCZ 12GB solutions allow users to take advantage of high density memory configurations when working with intensive design and multimedia applications.
The Platinum Series 12GB kit is designed specifically for the Intel® Core™ i7 processor / Intel® X58 Express Chipset. Optimized for the Core i7’s triple channel mode, these new 12GB kits ensure optimal performance via an ideal combination of low voltage requirements, speed, and latency.
OCZ Triple Channel solutions are the choice counterparts for leading-edge performance that won’t inhibit the functionality of Core i7 CPUs. In addition, modules are tested in matched triplets ensuring superior compatibility. All Platinum Series kits are 100% hand-tested and backed by the OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
Features:-
- 1600MHz DDR3
- CL 7-7-7-24 (CAS-TRCD-TRP-TRAS)
- Available in 12GB kits
- Unbuffered
- Platinum Z3 XTC Heatspreader
- 1.65 Volts
- 240 Pin DIMM
- Lifetime Warranty
Only £349.99 inc VAT.
ORDER NOW
Patriot Viper 2 Sector 7 12GB (3x4GB) PC3-12800C7 1600MHz Triple Channel Memory Kit @ £249.99 inc VAT
The Patriot Viper II 'Sector 7" Series, part of the Extreme Performance (EP) Low Latency line, is the ultimate performance memory solution for the Intel® X58 chipset and Core™ i7 processors. The Viper II 'Sector 7' series are built using only the highest quality pre-sorted IC's available and are subjected to rigorous testing and validation on the X58 platform to achieve optimized performance and maximum quality. These modules are engineered to reach PC3-12800 (1600MHz) at 7-9-7-21 timings and are available in 12GB kit capacity (3 x 4GB). Each module is 100% hand-tested for quality assurance and is backed by a full lifetime warranty and industry leading customer service.
Features
- Extreme Performance PC3-12800 (1600MHz)
- Low Latency (7-9-7-21)
- 1.65V
- Equipped Patriot Viper Heat Shields with integrated ACC (Aluminum Copper Composite) technology
- Lifetime Warranty
- XMP Ready for Core i7 Processors
Only £249.99 inc VAT.
ORDER NOW
Patriot Viper 2 Sector 7 24GB (6x4GB) PC3-12800C9 1600MHz Triple Channel Memory Kit @ £499.99 inc VAT
The Patriot Viper II 'Sector 7' Series, part of the Extreme Performance (EP) Enhanced Latency line, is the ultimate performance memory solution for the Intel® X58 chipset and Core??? i7 processors. The Viper II 'Sector 7' series are built using only the highest quality pre-sorted IC's available and are subjected to rigorous testing and validation on the X58 platform to achieve optimized performance and maximum quality. These modules are engineered to reach PC3-12800 (1600MHz) at 9-9-9-24 timings and are available in 24GB kit capacity (6 x 4GB). Each module is 100% hand-tested for quality assurance and is backed by a full lifetime warranty and industry leading customer service.
Features
- Low Latency (9-9-9-24)
- 1.65V
- Lifetime Warranty
Only £499.99 inc VAT.
ORDER NOW
Patriot Viper 2 Sector 5 4GB (2x2GB) PC3-18000C9 2250MHz Dual Channel Memory Kit @ £117.49 inc VAT
The Patriot Viper II 'Sector 5' Series, part of the Extreme Performance (EP) Low Latency line, is the ultimate performance memory solution for the Intel P55 system platform. The Viper II 'Sector 5' series are built using only the highest quality pre-sorted IC's available and are subjected to rigorous testing and validation on the P55 platform to achieve optimized performance and maximum quality. These modules are engineered to reach PC3-18000 (2250MHz) at 9-9-9-27 timings and are available in 4GB kit capacity. Each module is 100% hand-tested for quality assurance and is backed by a full lifetime warranty and industry leading customer service.
Features
- Extreme Performance PC3-18000 (2250MHz)
- Low Latency (9-9-9-27)
- 1.65V
- Lifetime Warranty
ORDER NOW
Corsair Dominator 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMD4GX3M2A1600C9) @ £74.99 inc VAT
This 4GB twin DOMINATOR kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock.
- Corsair Dominator memory (2 x 2GB)
- Form factor: DIMM 240-pin
- Memory speed: 1600 MHz
- Latency timings: CL9 (9-9-9-24 )
- Dual-path Heat Xchange (DHX)
- Intel Extreme Memory Profiles (XMP)
- Supply voltage: 1.65 V
- Built for Intel
Only £74.99 inc VAT.
ORDER NOW
OCZ Platinum 8GB (2x4GB) DDR3 PC3-12800C7 1600MHz Dual Channel Kit (OCZ3P1600LV8GK) @ £234.99 inc VAT
Configured for dual channel mode, these ultra-compatible 8GB kits ensure optimal performance with an ideal combination of low power requirements at 1600MHz. Developed for cost-conscious enthusiasts and gamers, these new OCZ modules were engineered with the same affordability and performance standards as the latest Intel and AMD platforms. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the Intel P55 and AMD 8 Series Chipsets to deliver the maximum stability.
OCZ DDR3 PC3-12800 Platinum Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
Features:-
- 1600MHz DDR3
- Unbuffered
- Platinum Layered Z3 XTC Heatspreader
- Lifetime Warranty
- 1.65 Volts
- Qualified on Intel P55 Chipsets and Core i3, i5, i7 CPUs
- Qualified on AMD 8 Series (Phenom X6 CPUs only)
- 240 Pin DIMM
- Lifetime Warranty
Only £234.99 inc VAT.
ORDER NOW
Patriot Viper 2 Sector 5 4GB (2x2GB) PC3-12800C8 1600MHz Dual Channel Memory Kit @ £76.36 inc VAT
The Patriot Viper II 'Sector 5' Series, part of the Extreme Performance (EP) line, is the ultimate performance memory solution for the Intel® P55 system platform. The Viper II 'Sector 5' series are built using only the highest quality pre-sorted IC's available and are subjected to rigorous testing and validation on the P55 platform to achieve optimized performance and maximum quality. These modules are engineered to reach 1600MHz at 8-8-8-24 timings and are available in 4GB kit capacity.
Features
- Low Latency (8-8-8-24)
- 1.65V
- Lifetime Warranty
Only £76.36 inc VAT.
ORDER NOW
Patriot Viper 2 Sector 5 8GB (2x4GB) PC3-12800C7 1600MHz Dual Channel Memory Kit @ £179.99 inc VAT
The Patriot Viper II 'Sector 5' Series, part of the Extreme Performance (EP) Low Latency line, is the ultimate performance memory solution for the Intel P55 system platform. The Viper II 'Sector 5' series are built using only the highest quality pre-sorted IC's available and are subjected to rigorous testing and validation on the P55 platform to achieve optimized performance and maximum quality. These modules are engineered to reach PC3-12800 (1600MHz) at 7-9-7-21 timings and are available in 8GB kit capacity (2 x 4GB). Each module is 100% hand-tested for quality assurance and is backed by a full lifetime warranty and industry leading customer service.
Features
- 1.65V
- Lifetime Warranty
Only £179.99 inc VAT.
ORDER NOW
OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Dual Channel (OCZ3G1333LV4GK) @ £64.61 inc VAT
OCZ low-voltage DDR3 kits are designed specifically for the upcoming Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of low power requirements at 1333MHz.
Developed for cost-conscious enthusiasts and gamers, these new OCZ modules were engineered with the same affordability and performance standards as the new Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and OCZ memory are the premium option for the midrange desktops.
OCZ DDR3 PC3-10666 Gold Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1333MHz DDR3
- CL 9-9-9-20 (CAS-TRCD-TRP-TRAS)
- Gold Z3 XTC Heatspreader**
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
Only £64.61 inc VAT.
ORDER NOW
Hopefully the 8gb kits will start to replace the 4gb ones soon, and come down in price (although some are already the same price per gb).
thoughs patriot viper 2 2250mhz kit look to be a good price. I am sure at the start of this year they were £500 at other places
