** ROUND FIVE ** WEEKEND ONLY DEAL! CRAZY MONITOR DEALS!!!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Two truly epic monitor deals, this weekend:-
DGM IPS-2701WPH 27" LED Widescreen Professional Monitor - Black @ £299.99 inc VAT
The IPS-2701WPH is DGM's new WQHD resolution monitor built around LED backlight LG IPS panels. Featuring a 2560x1440 resolution [WQHD], these monitors are ideal for creative professionals and gamers who demand nothing but the very best. IPS panels are preferred for their superior true color values, the most consistent image and a superior viewing angle as compared to other LCD technologies.
The DGM IPS-2701WPH features the same high resolution LED LG IPS panel found in the Apple Cinema Displays. Video content bypasses scalers making the DGM IPS-2701WPH ideal for gaming and multimedia video production. The superfast 6ms response [grey to grey] minimises streaking and ghosting resulting in visibly less smear and blur around fast moving objects.
Features:-
- Panel Size: 27" Diagonal IPS Panel
- Aspect Ratio: 16:9
- Resolution: 2560 x 1440 (WQHD)
- Pixel Pitch: 0.2331 mm
- Display Colors: 16.7M
- Brightness (cd/m2): 350cd/m2
- Contrast Ratio (Typ.): 1000:1
- Dynamic Contrast Ratio (Typ.): 80,000
- Response time (ms): 6ms
- Viewing Angle, H/V: 178 degree(H) / 178 degree(V)
- Input Signal: HDMI (Max resolution on HDMI is 1920x1080), Dual Link DVI-D, DP (Display Port), VGA (D-sub 15pin)
- HDCP Support: YES
- Internal Speaker: Built-in Stereo Speakers
- Wall Mount: VESA 100 x 100 mm
- Net / Gross Weight: 7.6 / 10.3 Kg
- Monitor Dimension (W*H*D mm): 645 × 487 × 172 mm
- Carton Dimension (W*H*D mm): 720 × 510 × 130 mm
- 3yr Warranty return to base with OcUK
Was [£419.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
OcUK QH300-IPSM 30" Professional Monitor - Midnight Grey @ £629.99 inc VAT
The OcUK QH300-IPSM 30” monitor is the perfect partner for graphics and visual media, where professional grade technology meets revolutionary design. The QH300-IPSM offers huge 2560x1600 WQXGA resolution bringing a whole new dimension to on-screen graphics. The LG S-IPS panel used in the monitor delivers unsurpassed levels of colour saturation which results in image clarity that allows for colours to be easily differentiated to bring unheard of precision and accuracy in visual reproduction. With Shimian’s stylish bezel design the QH300-IPSM won’t leave you disappointed when being admired on your desktop and with its Tilt, Pivot and Swivel features you can adjust the screen in a variety of ways to suit your individual needs. The QH300-IPSM is not just a great looking product with superb features it is also backed up with a 3 year collect and return UK warranty giving the user additional piece of mind in the knowledge that they have support should the encounter any unexpected problems.
Specification:-
- 30” WQXGA S-IPS Panel
- 2560 x 1600 Resolution
- 0.2505 x 0.2505mm Pixel Pitch
- 1000:1 / 1,000,000:1 Dynamic Contrast
- 60Hz
- 6MS Response time
- 370cd/m Brightness
- 178 Degree Horizontal/Vertical Viewing angles
- Inputs – DVI (Dual), VGA, HDMI, Component, Audi In, SPDIF, SVC Port
- Speakers: Stereo 5W + 5W
- 1.07 Billion Colors (10 Bit)
- Vesa compatible
- Software Compatibility – Windows 98/ME/2000/XP/Vista/Win7/Mac OS X
- Dimensions – 680W x 442H x 85D mm
- 3yr Collect and Return Warranty
Was [£719.99] Inc. VAT
Only £629.99 inc VAT.
ORDER NOW
Time to get yourselves a big 1440P / 1600P monitor me thinks. ;) :D
shame, was looking for a 24" 2ms monitor these are too pricey for me.
Just reduced this by a further £5, best can offer:-
BenQ GL2460 24" Widescreen LED Slim Bezel Monitor - Black @ £113.99 inc VAT
Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ GL2460 LED monitor is the perfect choice for you in style! Featuring Senseye Human Vision Technology with optimized Eco Mode and Reading Mode, a dynamic ratio of 12M:1, and 2ms GtG response time, this 24"W 16:9 LED monitor delivers every image detail with the best viewing quality.
LED backlighting offers significant advantages over the CCFL technology used in older LCD monitors. These advantages encompass not only performance metrics such as higher dynamic contrast, no light leakage and flicker-free, but also environmental factors, like a manufacturing process and disposal that produces fewer pollutants.
GL60 Series blends perfectly with any decor, adding a hint of low-key elegance to your living space with its high-gloss frame and base stand streamlined by a curvaceous neck that creates stunning visual fluidity. Beautiful from any angle, the back of the GL2460 is carbon fiber patterned to recreate the powerful drive of a racing car and energize their whole appearance. Incorporating a 16mm slim bezel display, GL60 Series creates a sophisticated look while keeping things nice and compact. You'll find multi-panel configuration for home entertainment or office viewing use much simpler with less distraction from the monitor frame.
For a more comfortable reading experience, BenQ has adjusted the monitor's color temperature, brightness, contrast ratio and sharpness to create the all new Reading Mode which simulates the look of printed paper to help reduce the eye discomfort typically caused by prolonged and focused use of eyes on computer monitors.
Features:-
- LED Backlit
- Screen Size: 24" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 12000000:1
- Brightness: 250cd/m²
- Response Time: 2ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant (100x100mm)
- Dimensions: 565.0mm x 434mm x 194mm
- Weight: 4.4kg
- Warranty: 2 Years On-Site
Was [£119.99] Inc. VAT
Only £113.99 inc VAT.
ORDER NOW
I was looking at that or the GL2460HM
However a competitor is selling the GL2460 £5 cheaper than that and their Sat delivery is also cheaper by £4.
Only difference I can see between the two is the speakers and the HDMI port for £30 extra which I dont really need although the speakers albeit poor ones would come in handy.
Decisions, decisions.
It's a shame you guys don't stock the same looking model as mine (BenQ G2420HDBL) as I'd have bought one in a heartbeat, if I had funds :p
I suspect the DGM is being cleared to make way for the new model coming soon but at this price I may have to buy one anyway. Shame I cant get it by monday though so gonna have loads a fun with delivery and work :(
It's not, this is a fresh delivery this Friday, new model is just this with a glass front, both models running side by side. :)
The ones you're selling now, do they have the same front as when you first started stocking them a year ago?
The upcoming new model won't come with a better stand with it?
Can anyone recommend an good value (ie. cheapish) upgraded stand that allows rotation between landscape and portrait?
well I have ordered one so lets see what its like. I have a replacement stand in mind if I cant get on with the original one (ive been spoilt by all my monitors having tilt/swivel and height adjustment up to now).
Interested in the pixel policy even though I know I have 14 days approval with OC.
yep me too
