** ROUND TWO ** WEEKEND DEALS!!!! Storage and SSD!
20 Jul 2009
The bleak North East arm pit of Britain
Hello
Round two of weekend deals kicks off with Storage!
Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD @ £48.95 inc VAT
The new Barracuda ST1000DM003 hard drive from Seagate offers customers a compelling new storage choice for high-capacity, high-performance computing solutions. The new Barracuda ST1000DM003 drive is built on a full-speed, 7200RPM platform. Further turbocharged with a huge 64MB cache and the industry’s new, high-performance SATA 6Gb/s interface, the Barracuda ST1000DM003 drive is destined to set a new standard for high-speed desktop performance. Discerning high-performance PC users, multimedia development professionals and power users in general will appreciate the capacity, performance and flexibility the Barracuda ST1000DM003 drive offers.
- Backwards compatible with SATA-II
- Capacity: 1TB
- Cache: 64MB
- Interface: SATA 6Gb/s
- Spin Speed: 7200RPM
- Warranty: 1 Years
Was £53.99 Inc. VAT
Only £48.95 inc VAT.
ORDER NOW
Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) HDD @ £39.95 inc VAT
Combining proven components, state-of-the-art technology and industry-leading manufacturing expertise, the Seagate Barracuda 7200.12 drive - the 12th generation of this award-winning desktop hard drive family - delivers 500GB of high-performing, eco-friendly digital storage.
- Capacity: 500GB
- Cache: 16MB
- Interface: SATA 6GB/s
- Seek Time: 8.5ms
- Warranty: 1 Years
Was £41.99 Inc. VAT
Only £39.95 inc VAT.
ORDER NOW
Seagate 500GB SSHD Solid State Hybrid Drive SATA 6Gb/s 2.5" 5400RPM 64MB - ST500LM000 @ £62.99 inc VAT
Get the best of both worlds!
Seagate® Laptop and Laptop Thin SSHDs fuse the lightning speed of SSD with the high capacity of a hard drive. Powered by Seagate Adaptive Memory™ technology, SSHD improves boot times and application speed dramatically, unleashing your system’s performance.
- 500GB, 7mm design for the latest, thinnest laptops
- Boots up and performs like an SSD
- Up to three times faster than a traditional HDD
- Easy laptop upgrade to boost performance and capacity.
- SATA 6GB/s
Was £67.99 Inc. VAT
Only £62.99 inc VAT.
ORDER NOW
Western Digital Caviar Green 2TB SATA 6Gb/s 64MB Cache - OEM (WD20EZRX) HDD @ £71.99 inc VAT
WD Caviar Green SATA hard drives reduce power consumption by up to 40% and offer best-in-class acoustics and operating temperature. Based on WD's exclusive GreenPower technology, these drives are designed to deliver power savings as the primary attribute. As hard drive capacities increase, the power required to run those drives increases as well. WD Caviar Green drives make it possible for energy-conscious customers to build systems with higher capacities and the right balance of system performance, ensured reliability, and energy conservation. They are ideal for PCs, external storage and other devices that require lower power consumption and cool, quiet operation.<br>
<br>
- Capacity: 2TB<br>
- Cache: 64MB<br>
- Spin Speed: IntelliPower (5900rpm)
- Warranty: 2 Years
Was £75.95 Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
Toshiba SSD HG5D Series THNSNH 7mm 60GB Solid State Hard Drive - (THNSNH060GCST) @ £59.99 inc VAT
Unlike magnetic hard disk drives, the more common storage solution used today, 60GB Toshiba SSDs have no moving parts and do not rely on magnetic fields to store data. Due to this fact, SSDs have plenty of advantages: They are exceptionally rugged, durable, reliable and offer a faster experience.
- Capacity: 60GB
- Maximum Read: 534MB/sec
- Maximum Write: 450MB/sec
- Max I/O Per Second (IOPS): 50000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC) 19nm
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Warranty: 3 years
2.5-inch, 7.0 mm Height
19 nm MLC NAND Flash
Fast Access and Transfer Rates
Excellent Power Consumption
Toshiba Strong Error Correction Code (QSBC)
Data Corrupt Protection from Unexpected Power Loss
Was £61.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
OCZ Vertex 2E Bigfoot 480GB 3.5" SATA-II Solid State Hard Drive - (OCZSSD3-2VTX480G) @ £149.99 inc VAT
OCZ Vertex 2 SATA II 3.5” Solid State Drives deliver the same industry-leading performance as the 2.5” edition in a larger, lower cost per gigabyte form factor to easily integrate into desktop applications without the need to install additional hardware.
Designed to excel in both sequential and random read/write speeds up to 50,000 4KB random write IOPS, the 3.5” Vertex 2 maximizes productivity when used as a primary storage or boot drive, minimizing program load times and completing tasks with blazing speed. Using the latest controller technology, the 3.5” Vertex 2 provides a faster, more responsive PC experience complete with TRIM support to keep your drive operating at peak performance in Windows 7 systems. Built with SATA 3Gb/s, Vertex 2 3.5” drives easily integrate into today’s desktop platforms as the ultimate storage upgrade.
Features:-
- Max Read: up to 250MB/s
- Max Write: up to 210MB/s
- Sustained Write: up to 160MB/s
- Random Write 4KB (Aligned): 15,000 IOPS
- Available in 90GB to 480GB capacities
- Native TRIM support
- Max IOPS Firmware
- Seek Time: .1ms
- 3.5" Anodized Casing
- 146 (L) x 101.6 (W) x 11mm (H)
- Operating Temp: 0°C ~ 70°C
- Storage Temp: -45°C ~ +85°C
- Low Power Consumption: 2W in operation,.5W in standby
- Shock Resistant up to 1500G
- RAID Support
- Compatible with Windows XP, Vista, 7, Mac OS X and Linux
- MTBF: 2 million hours
- Ideal for desktop systems (no need for converter brackets)
- 3-Year Warranty
Was £179.99 Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Adata XPG SX300 64GB mSATA Solid State Hard Drive - OEM (ASX300S3-064GM-C) @ £56.99 inc VAT
The increasing demand for high-performance system storage device is easily met by the Premier Pro SX300 mSATA 6GB/sec solid state drive. With a SandForce controller and 25nm (MLC) NAND Flash chips, the SX300 reaches random read and write speeds of up to 25,000/85,000 IOPS. When combined with the Sandy Bridge or Ivy Bridge platforms, the SX300 can achieve amazing performance on both desktop and notebook systems. The implementation of optimized firmware in the SX300 results in full utilization of the NAND Flash components, which translates to maximized storage capacity: a 7% increase over other solid state drives that use a SandForce controller. This zero percent over-provisioning is implemented with no loss to performance or supported features, and can be realized only by 100% screening and sorting of the NAND Flash.
- Capacity: 64GB
- Controller: SandForce SF-2281
- Maximum Read: 550MB/sec
- Maximum Write: 505MB/sec
- Max I/O Per Second (IOPS): 85000 IOPS (4KB File)
- Interface: mSATA
- Warranty: 3 years
Was £59.99 Inc. VAT
Only £56.99 inc VAT.
ORDER NOW
Adata XPG SX300 128GB mSATA Solid State Hard Drive - OEM (ASX300S3-128GM-C) @ £89.99 inc VAT
- Capacity: 128GB
- Interface: mSATA
- Warranty: 3 years
Was £95.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Adata XPG SX300 256GB mSATA Solid State Hard Drive - OEM (ASX300S3-256GM-C) @ £179.99 inc VAT
- Capacity: 256GB
- Interface: mSATA
- Warranty: 3 years
Was £193.99 Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
Oh god not the weekend 'round #' deals again, I'm supposed to be saving for 780's and ib-e :(
Edit: get some water gear up and I may be tempted ;)
I was watching the prices come down to £135 ish on the Seagate 4TB's but seem to be going up quickly again.
Just got a pile of 2TB's versions at work, and a single 3TB for my desktop. So quiet, no drive clicks at all.
Think i'll hold out for maybe 3TB's at £100 then :-)
Is that SSD up to much? I nothing about them but the price/size ratio looks good...?
Its not the fastest thing in the world as its older tech but for a team drive you cant go wrong. Its exactly what i use mine for. Instant game loading compared to an HDD and the game feels more fluid as textures are loaded up quicker etc. Certainly worth it for that, as an OS drive its still much better than an HDD but its not something I would personally use for one.
I keep getting tempted by those but have just bought a WD green 1 tb to replace my old samsumg F2 drive that recently died taking all my games stuff with it :mad:
Ta buddy, will think about it. :)
It's not the 480gb drive pictured. You will recieve a curved ended drive with slightly lower speeds called a vertex 2 which had been refurbed with a new case shape rather than a 2-Extreme as advertised which used to be the old box shaped 3.5in drive pictured. Overclockers are not fully aware of this as the box indicates a different contents until unsealed so not their fault but we've bought a few and they are the basic 2-version with the 30% high failure rate inside 6 months but as a steam drive I guess the risk is just about worth it but I wouldn't raid-0 these things!
Do not get the Vertex 2E Bigfoot. I have a smaller capacity one and it is really unstable as a boot drive.
More importantly, it appears there are major compatibility issues with the Z87 chipset since the Sandforce controller does not adhere to the SATA spec. This means that it will also likely be incompatible with future Intel chipsets.
crap! It cannot be true that SF does not adhere standards. May be you are having some compatibility issues with your existing hardware. The newer sandforce ssds are widely compatible & unless you prove your point with any substianial material I dont think anyone on this thread would listen to you!
http://www.ocztechnologyforum.com/forum/showthread.php?111964-Vertex-2-Agility-2-and-Haswell
http://rog.asus.com/forum/showthread.php?34217-Sandforce-SSD-not-supported-by-Haswell&p=277220
