rounded off wheel nut on bmw
Last time I had to do this, I walloped a deep 12 sided imperial socket over it with a lump hammer and removed the nut using that.
Why would you drill out a wheel bolt or weld a socket onto it when there’s a tool that’ll remove it in seconds?
Depends on the way the alloys are. I had to drill out a stud once because there wasn't anyway to get anything on it to get it out.
In that situation I can recommend dormer drill bits. They are the dogs danglies.
