Hi all,
I am looking for a WiFi router which allows me to create a VLAN on a separate subnet where DHCP is enabled. The router would then sit on another network which provides internet access via WLAN. This WLAN and the aforementioned VLAN should be able to talk - but kept separate.
As an example, the router is 192.168.0.100, its gateway is 192.168.0.1 via WLAN. The router should be able to generate a VLAN on 192.168.10.0 with DHCP. Computers on 192.168.10.0 should be able to talk to 192.168.0.0 and also access the internet.
I know a Draytek can do that but it's like using 1% of its capabilities and they are very expensive - at least for my needs.
Is there anything else which could be used that can do the above?
Thanks
Tony
Thanks
Tony
