- 3 Apr 2020
Looking to change my BT Smart Hub 2 out for a better routed around the £100 mark, What do you guys recommend? Im on full fibre
TIA
TIA
How exactly is the Smart Hub lacking for you?Looking to change my BT Smart Hub 2 out for a better routed around the £100 mark, What do you guys recommend? Im on full fibre
TIA
You can get ones with gigabit ethernet ports but you're never going to be able to make full use of your 900Mbps FTTP connection if you're using Powerlines.
