Router and Network Advice
7 Mar 2005
The Voice Of Football
Devices seem to keep losing connection to my bog standard Bebox Speedtouch router setup so I think it is time for a refresh. Technology has passed me by for a few years so I need some recommendations :)
I currently have the following setup:
Bebox ADSL router hardwired in to a PC. This also acts as a wifi connection to the bedroom where I have a internet radio.
Linksys router running DD-wrt in the lounge hooked up to a printer and popcorn hour via ethernet.
Other wireless devices such as ipad, ps3, xbox and laptops etc connect to the network.
I basically want to replicate the setup so I have the adsl modem router in the pc room and the bridge with ethernet hub in the lounge. I would also like to add an apple TV at a later date and stream hi-def to the TV in the bedroom from the popcorn hour.
In terms of hardware what would folks recommend for this task?
Thanks for your time and help in advance :)
I might move to infinity not sure though as I am very happy with bethere but you never know.
Budget- don't want to spend loads and loads but will spend what I need. Probably under 100 for the lot unless there is a darn good reason
