I just brought the Asus n56u router and the set up was good and the router was really quick and the signal was good. but every so often the router will just drop the connection and if I try to access a page it will say "You have set the wrong changing or static IP location for your RT-N56U"
I have to go to the main router page "192.168.1.1" and renew the connection in order to make it work. But when it works; it works really good.
Can anyone help??
It makes it almost impossible to play call of duty because the connection just drops out for no reason.
Router firmware: 1.0.1.7f
Can anyone help??
