bee said:i'd agree the old linksys routers with linux based firmwares were good , the new ones arent so hot though , just whatever you do stay away from netgear.
FunkyT said:The NETGEAR DG834G is rock solid...
BoomAM said:The 54Gs are aparentely dodgy. Although mine worked for over a year withour flaws.
The 354G is the way to go now.![]()
Burbleflop said:Not if your on Max and your SNR is a bit iffy they're not.
FunkyT said:This site (taken from the OcUK FAQ) doesn't seem to agree: "The Netgear DG834 and Westell 6100 are 2 routers that have been known to maintain a more stable connection on a low SNR line"
Ref: http://www.kitz.co.uk/adsl/lowSNR.htm
Burbleflop said:I tend to go on my personal experience and that of other people I know rather than what a sales organisation says.
FunkyT said:I agree with your logic but I don't think http://www.kitz.co.uk are a "sales organisation". If the accuracy of the information they provide is questionable, should they be listed in the OcUK FAQ?
Absolute rubbish - I don't mean to judge you for taking that as an example, but the info in there is very wrong. I've had one for 2.5 years and have to say that it does not hold a connection very well on a long line - mine with Attn of 53dB. It could only manage 3Mbp/s on Max. My Belkin 7633 has managed to get me a max stable rate of 5Mbp/s on this very long line!FunkyT said:This site (taken from the OcUK FAQ) doesn't seem to agree: "The Netgear DG834 and Westell 6100 are 2 routers that have been known to maintain a more stable connection on a low SNR line"
Burbleflop said:As for if that site should be listed in the FAQ, personally I wouldn't list it, but it isn't up to me.
...back in the days of USB modems being the 'in thing'tolien said:If you take it in context, the link's purely for giving instructions for extracting stats from modems/routers where it isn't necessarily obvious
Suspect the information on there's not necessarily wrong but just old (ie. pre-Max), when the AR7 chipset was generally regarded as one of the "better" options on marginal lines.
smids said:Absolute rubbish - I don't mean to judge you for taking that as an example, but the info in there is very wrong. I've had one for 2.5 years and have to say that it does not hold a connection very well on a long line - mine with Attn of 53dB. It could only manage 3Mbp/s on Max. My Belkin 7633 has managed to get me a max stable rate of 5Mbp/s on this very long line!
This does not mean to suggest it is a bad router. It served me very well for 2.5 years but it is known that on a long line the router is not as steady as others, not by a long chalk.
