6 Sep 2012 at 14:09 #1 cjenks22 cjenks22 Associate Joined 16 Aug 2011 Posts 146 Hey guys i need a new router preferably for gaming and streaming needs a good range and not to shabby on the speed. i currently have the dlink 615 which isnt to good Any help will be appreciated
6 Sep 2012 at 14:17 #2 KIA KIA Man of Honour Joined 14 Nov 2004 Posts 13,877 ASUS RT-N16 http://www.overclockers.co.uk/showproduct.php?prodid=NW-060-TP&groupid=46&catid=1596&subcat= http://www.overclockers.co.uk/showproduct.php?prodid=NW-024-TP&groupid=46&catid=1596&subcat= http://www.overclockers.co.uk/showproduct.php?prodid=NW-050-TP&groupid=46&catid=1596&subcat=
6 Sep 2012 at 16:31 #3 cjenks22 cjenks22 Associate OP Joined 16 Aug 2011 Posts 146 Whats the difference between TL-WR1043ND and TL-WR1042ND and personally which one would you go for between the 4 you listed? Thanks for your reply.
6 Sep 2012 at 17:12 #4 KIA KIA Man of Honour Joined 14 Nov 2004 Posts 13,877 One is out of stock. You'll have to compare the spec @ the TP-Link site. My pref is the ASUS RT-N16.
6 Sep 2012 at 20:11 #5 cjenks22 cjenks22 Associate OP Joined 16 Aug 2011 Posts 146 Just bought the ASUS RT-N16 thanks for the recommending it should i install usb tomato on step up? and are there any good tutorials?
6 Sep 2012 at 22:00 #6 KIA KIA Man of Honour Joined 14 Nov 2004 Posts 13,877 cjenks22 said: Just bought the ASUS RT-N16 thanks for the recommending it should i install usb tomato on step up? and are there any good tutorials? Click to expand... Definitely. http://tomatousb.org/tut:installing-on-asus-rt-n16 http://www.polarcloud.com/firmware
11 Sep 2012 at 14:23 #7 cjenks22 cjenks22 Associate OP Joined 16 Aug 2011 Posts 146 Got my tomato installed what settings should i change if any?
