hi,
My router is in the sitting room. I use a very long ethernet cable to plug it into the pc. What do I need if I want to connect the ethernet cables onto ps5 and xbox and pc.
so If I plug the ethernet cable into a
NETGEAR PoE Switch 5 Port Gigabit Ethernet Plus Network Switch, then plug ethernet cables in to the switch to pc, xbox and ps5.
