Hi,
I used to use a server as a gateway to the net and have other PC's networked via a switch.
Wanting to save power as I no longer use the server I decided to buy a router. The router is a Belkin N1 Wireless Router
I have two PC's plugged into the ethernet ports and a laptop working on the wireless. Everything net wise is working fine with no problems.
Heres the problem:
When I run Newsleecher I can't download any faster than 80-120 KBPS.
I went into the router control panel and disabled the firewall as a test which made no difference. I then seen settings for virtual servers which has a list of different games and programs.
I selected News Server (NNTP) and put in the IP address of the PC and saved the changes. This still made no difference to Newsleecher.
I done a speed test on the net to see if it wasn't just Newsleecher and I am downloading at 500-1000 KBPS yet Newsleecher still only gives 80-120 KBPS
I changed my network back to it's original config with the server as gateway just to make sure it wasn't the news servers being slow. Straight away I was getting 1.03 MB/s no problem at all.
So the problem seems to be within the router but I cannot see how to get Newsleecher at full speed.
Any ideas or advice is appreciated.
Thanks for your help.
Dan
Heres the problem:
Dan
