Router Help
8 Oct 2005
Midlands, UK
Hi All,
I'm considering buying a router, although have no clue on whats good/bad etc. I want to network 2 PCs, one laptop, a printer and an xbox 360. Can anyone quickly recommend me anything?
Thanks
hmm we need more info from you to give you a list of good routers
like are you on adsl or cable. and does your laptop as a wifi connection
as for the pcs and xbox 360 all routers will support them via ether-net ports
most come with 4 ether-net ports.
there are also 3 ways you can share the printer over a network
1 via connecting it to the pc and sharing it (connected pc as to be on for it to work)
2 using a Print Server box that connects via cable or wifi
3 using a router with a Print Server built in
