Router issue
Kol
Kol
Man of Honour
8 Jan 2003
Ashby-de-la-Zouch
Hi guys,
You may remember a few months ago I had some issues with my router not allowing me to stream UDP connections, however, directly connecting without the router meant I could.
Long story short, I changed router for this connection and it used to work fine. However, I've just got back to this residence and whenever I try and stream (max stream is about 5mbps, if that) over wireless, it is all choppy and breaks up. Connected via cable to the router it can handle it. I would have thought the wireless would be fine as transfers can go at easily up to 18mbps so the streaming should be fine?
I have also tried setting the software I use to stream to cache 10seconds worth, but that doesn't solve it. It's as if the packets of data are lost on the way.
