Ok so i have been using the DG834GT on O2 Home Broadband for awhile now and its been fine, but ever since MW2 came out, I have had serious issues when it comes to me hosting. My NAT is reported as OPEN in the game, so thats ok, but in-game everyone jitters about expect me. When i look at their pings, it seems fine (3bars for most and some on 4). This of course results in people leaving which is annoying as you can imagine.
Anyway, i have been opening all the ports required (multiple times, deleting them and trying again), but still no luck. I also tried "Pingtest" and it fails the Packet Loss test, resulting in an overall grade of "B". The ping is normal for me, around 36ms. I thought this was odd, and even after opening the ports for Pingtest, it still fails.
Tonight i decided to plug the old O2 Wireless Box II back in and try it to see if it worked and it did pass the Packet Loss test with 0% and the same ping of around 36-37ms. Now i haven't been able to try hosting MW2 since its really a luck of the draw in public games and also i don't have anyone to test it with online at the minute.
So i was just wondering what the problem could be? The Netgear is fine and gives me pretty much the same speeds as the O2 Box, a tad faster maybe. I would prefer to use the Netgear, but its really annoying doing some matches and then when it comes to me everything goes wrong!
If there are any logs or anything that i should check and post then i'd be glad to as im not really sure where to begin!
Cheers
Cheers
