- 17 Jan 2006
I have been using my Speedtouch 585 broadband modem/router for the last 4 years or so and had very few problems with it, however in the last couple of months it seems to have developed a problem.
Several times now the internet connection has stopped working, no pages will load, everything just times out of I get told I need to be connected to the internet.
The internet light on the router is illuminated green - which means the router is connected to the internet - and when I log into the web-interface and check the connectivity of the internet connection it says it is working fine - taking only moments to check - (I have had times when the problem has been at my ISP's end and it's taken much longer to check the connectivity) but still no pages will load etc.
If I switch the router off and back on again it does the usual restarting stuff and the lights gradually come on and go green, the dsl syncs up and it connects to the internet again and low and behold everything is working fine on the pc again, internet etc all nice and quick as they should be.
I also had a problem with the wifi connection and DCHP server whereby everytime I tried to connect my HTC Desire Z, it would get stuck at when obtaining an IP address from the router and wouldn't work. I got round this by setting a static IP on the phone, but even that sometimes fails to work properly.
Is it likely that my router is on it's last legs? It is getting on a bit and there are no firmware upgrades available for it.
If it is likely that the router is dying, are there any standout replacements anyone cna recommend...without me having to spend too much (the speedtouch was about £60)
Any help/thoughts much appreciated.
valve
valve
