- 28 Dec 2006
- Epsom Downs
Ok i've had this problem awhile and it never really bothered me too much, but if i'm caneing the internet or the local network my router locks up, stops sending reciving any thing, DCHP ping the lot !!
Even when you plug a network cable in windows says there is nothing on the end "network cable unplugged"
I've had it, and i now want a good router that has PnP and has 4 or more 100 Megs ( or even 1 gigs
) Wireless would be a plus, but not needed....
It needs to be stable as i use my local network to ship large amount of data around ( ie backing up peoples PCs ) can still use the internet...
so trying to suft the net on one pc and transfer 50 gigs from another pc to another pc.....
Any help?
Thanks
) Wireless would be a plus, but not needed....It needs to be stable as i use my local network to ship large amount of data around ( ie backing up peoples PCs ) can still use the internet...
Any help?
Thanks
