Hi! I've been using a BT Voyager 2091 to connect to Tiscali since I got a Wii in December. So far it has worked perfectly.
Then yesterday I was connected all morning with no problems. I shut down the computer as usual, but when I rebooted a couple of hours later, it wouldn't connect. I tried restarting, unplugging, switching cables etc etc but nothing worked. The lights are on and the LAN seems to be fine. I just tried plugging it into my Xbox 360 (which has always worked before), but it said something about how it couldn't connect to the DNS server.
I haven't installed any software/hardware or changed any settings at all, and the router appears to be working ok, so I can only assume something has changed at Tiscali's end.
Any ideas? I'm now using the USB modem that Tiscali supplied originally. Am I supposed to be using a BT router with a non-BT line or am I going to get in trouble? Can I mention it to Tiscali?
As you can tell, I'm not too hot on networking etc...
Any advice appreciated.
Cheers,
j98
Cheers,
j98
. Try all the different cables and things first before ringing, this'll save you a fortune in phone bills. Tell them you want a line check and to be upgraded to an engineering team from the get-go. Ring them between 5 and 7.00 on week nights to get straight through to an operator, weekends is met with 30+ minute ques. If your even remotely dissatisfied tell them to pass you on to their supervisor, and don't let them fob you off.
It took me over a year to escape from NTL and their debt collectors letters, despite trying to cancel the account 5 or 6 times.
