Hi
Our Linksys WAG325N is broken and out of warranty, so I'm after a new one.
We live pretty much the furthest away possible from the exchange and get 512Kbps max. It's also an extremely unreliable line.
When we first moved here we had a USB modem that would connect to a PC and share the connection. Every single day this would disconnect.
We then bought a Zyxel which kept the line up a lot better, however that broke.
We then bought the WAG325N which has been quite good.
Any recommendations? Here's our stats from the temporary BT Homehub if they help:
I'm also wanting to upgrade our network to gigabit, however a separate switch can be bought for that if necessary.
Also needs decent wireless. Budget is ~£80 or less.
[Edit]
Oh, and needs a modem. Doesn't need to be built in, but if it isn't then could someone recommend a separate one as well please.
Thanks
Craig.
Code:
Uptime: 0 days, 16:49:02
Modulation: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 224 / 512
Data Transferred (Sent/Received) [MB/GB]: 159.67 / 2.05
Output Power (Up/Down) [dBm]: 12.0 / 14.0
Line Attenuation (Up/Down) [dB]: 31.5 / 63.5
SN Margin (Up/Down) [dB]: 6.0 / 5.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 4 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 19 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 2,234
HEC Errors (Up/Down): 0 / 796
[Edit]
Thanks
Craig.
